Old 11th December 2003, 04:15 AM   #11
netgeek is offline netgeek  United States
Paul,
Thanks for the links! Very interesting read...
I think I may try this sequence of events in order to experiment (well, until I change my mind - which might be an hour from now, three days from now, or basically at any time until I've actually built something ):
1. Build a baffle of approximately 12.5" by 40". Stuff the Vifa 8" and Vifa tweeter recommended by Linkwitz into the top. Near the midsection, put in the Peerless CSC-X 10" driver. See what happens (i.e. measure, measure, measure - correct, correct, correct - using active circuitry to tweek the thing - notch filters, various slope, low freq. extension, etc. - this is stuff I can actually do and enjoy - measuring speaker enclosures, etc. is dreary stuff to me because it smells like too much math ).........
2. If more low end is required, add another CSC-X driver and adjust the amplification available (still have room on the large baffle mentioned above)...
3. If still unsatisfactory - replace second CSC-X with Peerless XLS and retest and align..........
4. Depending on the outcome of (3) above - consider enclosing the subwoofer section (still easy because of the open baffle) and test various enclosure volumes, sealed vs. ported, etc.
5. If we've gotten this far and still don't have something reasonable - start perusing the adverts for used Quad, Magnapans, etc. - and stock up on beer before the bank account is depleted - i.e..............DONE!!!!.....
I think eventually I'll just get started with the experiments instead of trying to analyze it all to death... Should be fun!!!
Bill
Old 11th December 2003, 04:16 AM   #12
Well, I sent the Email off to Parts Express about the Vifas. Unfortunately, they do not carry Capslock's M25WO47.
I sent off to ask about the symmetrical magnetic system for the following woofers:
P21WO-20
MG22W009-08
TC18WG49-08
I must admit that it doesn't look good for any of these having a shorting ring or an extnded pole piece, the way a symmetrical magnetic field is achieved. The reason is that as I looked at the Parts Express website, only the XT line mentioned anything like "a low distortion optimized motor system", which sure sounds like a symmetrical magnetic field. However, the XT line starts at around $100 for an 8" woofer-more expensive than the other Vifas.
I'll let you know if Parts Express responds.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 11th December 2003, 07:20 AM   #13
paulspencer's Avatar
Bill,
I have two suggestions. Instead of the CSX, use the Peerless 831857 - it is only slightly more expensive and as a 12" driver won't have to work as hard as the 10" CSX. A single CSX works in a smaller vented box than the 12" but for dipole use I'd go the 12. Also I would use 2 in push pull mode as this gives lower distortion. Otherwise I think your output with one CSX in open baffle operation will be marginal, personally I wouldn't even try it. Yes the XLS does have more output but it is also twice the price, for not much more output.
Happy experimenting
cheers,
Paul
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 11th December 2003, 07:35 AM   #14
frugal-phile(tm)
planet10's Avatar
For a pr of cheap subs have a look at the ApexJr 8" Subwoofer and the OEM VIFA 8" that steve has at ApexJr.
And for really Frugal-phile(tm) set of woofers nothing works as well as a set of 10 or 12" extended range drivers salvaged out of a set of dirt-cheap thrift store specials -- find some older ones where the surrounds aren't foam and you often find something decent (i've a growing collection of Corals & Fosters)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th December 2003, 08:33 AM   #15
Andreas is offline Andreas  Denmark
Planet10, slightly OT
The drivers on the left picture, thats a coral 12L60 or something, i might have a pair lying around in the basement somewhere. Had them 15 years ago in a 125L ported enclosure giving lots of rumble.
Have u tried to do anything with them yet ?
cheers
Andreas
Old 11th December 2003, 11:19 AM   #16
Stay away from the Peerless CC-260 woofer, much higher distortion than the CSX257. Only advantage is a porous dustcap that lowers wind noise, but has other side effects.
I believe the current version of the Vifas is M25WO49. There were various versions over the last couple of years with essentially the same parameters. Only difference I could find was dustcap design. I am not saying they are the perfect dipole woofer driver, but if you can get them cheaply, they will do a pretty good job.
Eric
Old 11th December 2003, 05:50 PM   #17
frugal-phile(tm)
planet10's Avatar
I'd have to go downstairs to check the number, but it is a 10" Coral. Plans were to use it with a pr of very special 3" Tandbands, below about 250 Hz in an active system.
dave
Old 22nd December 2003, 06:01 PM   #18
hifidan is offline hifidan  Canada
Default Peerless 831727
I have built 2 isobarik subs using the above in iso-barik config in a bass reflex 75 liters box, I ended up with an F3 at about 23 hz and clean output up to 97 db which is pretty good. Awsome with music, drawbacks are they can bottom on HT, Am using Peerless 10 inch XLS with passive in a 1 cu ft box for HT, F3 of abour 32 Hz but a lot more punch.
Cheers
Dan
HifiDan
looking for a small 2" or 3" driver with poor bass response space-cake Full Range 3 27th December 2007 01:16 AM
Small subwoofer drivers like 5" Tangband Tenson Multi-Way 10 25th August 2006 05:27 AM
WTB: a small 8" or 10" subwoofer justpoor Swap Meet 0 26th February 2006 09:05 AM
Suggestions wanted- 10" Subwoofers for very small bandpass enclosures. treedog Car Audio 6 16th January 2005 05:17 AM
suggestions; looking for shallow 10 or 12" woofer to work in small sealed box zuki Multi-Way 6 1st April 2004 06:21 AM
Page generated in 0.10982 seconds (80.47% PHP - 19.53% MySQL) with 11 queries
