My current sub is a BR and I was wondering if the Monacor SPH-450TC can be used at a lower frequency then in a BR?
(http://www.diyaudio.com/forums/subw...ht-sub-stealth-corner.html?highlight=pivoting)
This is a good opportunity for me to learn HornResp, I would like to learn to design horns.
Can someone jump-start me in HornResp with this driver?
I have about 600 litre net to spend, maximum outside dimensions are:
Initial dimensions were wrong!
height 2m 38cm
width 81cm
depth 33cm
These are correct:
height 2m 45cm - 8.038 ft
width 86cm - 2.822 ft
depth 38cm - 1.247 ft
i don't even know what kind of horn is to be simulated, I'm a novice.
Thanks.
[Driver]
Brand=Monacor
Model=SPH-450TC
Manufacturer=Monacor
ProvidedBy=Bart
DateAdded=20121010
DateModified=20121010
Qts=0,25
Znom=8
Fs=20
Pe=1000
SPL=93
Re=7,4
Le=0,0046
fLe=0
KLe=0
BL=32,4
Xmax=0,0129
Cms=0,00022
Qms=2,97
Qes=0,27
Rms=12,7
Mms=0,305
Sd=0,125
Vas=0,48
Dia=0
Vd=0,0016125
no=0,0137
Dd=0
EBP=0
numVC=1
Hc=0
Hg=0
SPLmax=0
SPLmaxLF=0
USPL=0
alfaVC=0
Rt=0
____________________________________
Impedanz (Z)
2x4 Ω
Resonanzfrequenz (fs)
20 Hz
Max. Frequenzbereich
f3-1500 Hz
Empf. Trennfreq. (fmax.)
400 Hz
Maximale Belastbarkeit
2x500 WMAX
Nennbelastbarkeit (P)
2x350vWRMS
Mittl. Schalldr. (1 W/1 m)
93 dB
Nachgiebigkeit (Cms)
0,22 mm/N
Bewegte Masse (Mms)
305 g
Mech. Widerstand (Rms)
12,7 kg/s
Mechanische Güte (Qms)
2,97
Elektrische Güte (Qes)
0,27
Gesamtgüte (Qts)
0,25
Äquivalentvolumen (Vas)
480 l
Gleichstromwiderst. (Re)
2x3,7 Ω/1x7,4 Ω
Schwingspulenindukt. (Le)
2x1,1 mH/1x4,6 mH
Schwingspulendurchmesser
99,3 mm
Schwingspulenträger
Alu
Schwingspulenwick.-Höhe
37,8 mm
Luftspalthöhe
12 mm
Lineare Auslenkung (XMAX)
±12,9 mm
Eff. Membranfläche (Sd)
1250 cm2
Verschiebevolumen (Vd)
1612,5 cm3
Kraftfaktor (BxL)
32,4 Tm
Referenz-Wirkungsgrad (No)
1,37 %
Magnetdurchmesser
220 mm
Magnetgewicht
5,7 kg
Einbauöffnung
Ø 425 mm
Einbautiefe
220 mm
Abmessungen
Ø 460 mm
Gewicht
17 kg
height 2m 38cm
width 81cm
depth 33cm
These are correct:
Thanks.
[Driver]
Brand=Monacor
Model=SPH-450TC
ProvidedBy=Bart
DateAdded=20121010
Qts=0,25
Znom=8
Fs=20
Pe=1000
SPL=93
Re=7,4
Le=0,0046
fLe=0
KLe=0
BL=32,4
Xmax=0,0129
Cms=0,00022
Qms=2,97
Qes=0,27
Rms=12,7
Mms=0,305
Sd=0,125
Vas=0,48
Dia=0
Vd=0,0016125
no=0,0137
Dd=0
EBP=0
numVC=1
Hc=0
Hg=0
SPLmax=0
SPLmaxLF=0
USPL=0
alfaVC=0
Rt=0
Impedanz (Z)
2x4 Ω
20 Hz
f3-1500 Hz
400 Hz
2x500 WMAX
2x350vWRMS
93 dB
0,22 mm/N
Bewegte Masse (Mms)
305 g
12,7 kg/s
2,97
0,27
Gesamtgüte (Qts)
0,25
480 l
2x3,7 Ω/1x7,4 Ω
2x1,1 mH/1x4,6 mH
99,3 mm
Schwingspulenträger
Alu
37,8 mm
Luftspalthöhe
12 mm
±12,9 mm
1250 cm2
1612,5 cm3
Kraftfaktor (BxL)
32,4 Tm
1,37 %
Magnetdurchmesser
220 mm
Magnetgewicht
5,7 kg
Einbauöffnung
Ø 425 mm
Einbautiefe
220 mm
Abmessungen
Ø 460 mm
Gewicht
17 kg
Hornresp Tutorials
Hi Bart,
I don't know if there is a tutorial that addresses the new Wizards, but these two are good:
By lilmike:
Simple Tapped Horn Tutorial using Hornresp
By soho54:
Hornresp for Dum... hmm... Everyone - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
I think my T/S parameters were partially from the manufacturers data sheet, and partially recalculated by Hornresp.
Hi Bart,
By lilmike:
By soho54:
Hi Bart,
You are calling this: "18" in horn for HT". I went on the assumption, that a front loaded horn would just be way too big ("...lower frequency...HT...), and that a tapped horn would be about the maximum size/output compromise. While learing Hornresp you may also want to try the other 1/4 wave resonators and transmission lines that have been popularized on this forum by bjorno, the tapped versions (QWP and T-TQWT), as well as the offset driver enclosures (OD-MLTL and OD-TTL). I'm sure you'll find other names and examples using "search". They will get you lower in a reduced volume with improved group delay.
FYI, a driver’s cab loading BW is defined by Flm = Fs*Qts/2 and Fhm = 2*Fs/Qts, though for Prof. Leach’s horn design routine, use Qes and of course it’s best to use measured specs.
With the understanding that the further below the driver’s upper mass corner [Fhm] the desired gain BW extends the less peak power handling is available; this driver’s low Fs, Qts means a very wide usable horn loading BW, so with its fairly high power handling capability, horn loading to below Fs is viable, though its high Vas means a relatively large cab.
GM
GM
What does BW stand for?
Flm= 20*0.25/2= 2.5
Fhm= 160
I tried to measure T&S parameters but ATB-PC Pro doesn't measure below 12hz, so it couldn't determine the lower impedance peak or something like that.
Even if it did work suddenly, then it would be even worse with the added mass.
I gave REW a go but didn't figure out enough to use it properly...
Flm= 20*0.25/2= 2.5
Fhm= 160
Hi Bart,
I noticed a few things about your simulation in Post #12:
- the L34 dimension should be at least 1/2 the driver frame diameter for the driver to fit into the box,
- S1 does not have to be larger than Sd, it could be even as small as 1/2Sd (not quite sure about this, but that's how I interpret some of bjorno's simulations),
- in the Speaker Wizard, setting S2 and S3 to Auto makes things easier
- I recommend you keep the segments at Par,
- if you are simulating at higher power than reference (e.g.: 1W/1m) try to keep the maximum displacement in the Filter Wizard at or below Xmax (in my example about 300W/8Ohm).
I'm struggeling on here, lol.
Thanks for the help guys, much appreciated!
The space that I have to put the sub in is:
height 2m 38cm - 7.808 ft
with 81cm - 2.657 ft
depth 33cm - 1.083
Just downloaded Arta and the help files.
I will check in HornResp and see what Oliver is talking about, great stuff. I like the graphs.
It's 21:30 here, time for a movie with the prototype BR sub.
Can't be all thinking and no fun, right?!
depth 33cm - 1.083
Didn't have time to learn about horns properly and 'hupla', epa has a 'ready to build' solution... incredible...
Now my motivation is gone to learn HornResp...Thanks a lot...
lol
I'll sure play around with the numbers in your HR sim but there isn't much room of course, the maximum dimensions are fixed.
Just want to see if the top end can be extended without loosing the low end.
I see you used quarter space instead of eighth space, why is that?
How thick is the wood in your drawing?
lol
OMG, I made a stupid error, sorry about that!
When I wrote the dimensions I already kept in mind the thickness of the boards and bracing, so the dimensions that I can use for the outside of the box are bigger.
I realized this when I saw the volume was only 430l instead of the 600l that I came up with.
I hope you aren't too disappointed, epa.
OK, I checked this twice to be sure:
One thing I was wondering about is, the depth behind the driver, is there enough room? I mean, for the venting.
An end loaded tapped horn is limited to ~three octaves and ~two octaves for an off-set driver or inverse tapered one [T-TQWT], so yes, you 'rob Peter to pay Paul' within these limits as you shift its mean BP tuning [(Fl*fh)^0.5] up/down.
Here’s a ~three octave TH Vs its inverse ~two octave T-TQWT equivalent in 600 L net/522.78 cm path-length, which clearly shows the theoretical BW limits and extreme tuning difference, power handling capability.
GM
GM
- Subwoofers
- 18" in horn for HT
