What Plywood are you buying?
Old 6th July 2013, 03:19 PM   #11
DrDyna is offline DrDyna  United States
DrDyna's Avatar
Originally Posted by lanchile View Post
That is why there are masks
Oh, I wear a mask most of the time, it's just a pain, that damn dust gets into everything, it's nearly impossible to avoid it completely.
Old 6th July 2013, 03:21 PM   #12
lanchile is offline lanchile  United States
lanchile's Avatar
Originally Posted by tinitus View Post
funny statement if you have never used anything else
this year I have built several projects using plywood .... and have almost become an addict, making all sorts of nice things from the leftovers
lol...yeah I ment I DID try with plywood and but, MDF is the way for speakers enclosures. Plywood is good for the rest.
Make it simple...Make it better!
Old 6th July 2013, 03:38 PM   #13
lanchile's Avatar
My friend works for a big company that build cabinets and speaker enclosures and He has in his house a BIG exhaust fan "attached" to his table saw that gets MOST of the dust out. He used to build MDF speaker cabinets for me long time ago. I think it will help a lot an exhaust fan that can take all the MDF dust out or filtered kind of way.
Old 6th July 2013, 03:48 PM   #14
lanchile's Avatar
To me the only downside if that is one lol. is MDF is way heavier than plywood and solid wood. But as I said before, MDF is the way to build cabinets for speakers. MDF is the choice of material used in well known and reputable speakers companies. if they trust MDF material for speaker enclosures...so should We.
Old 6th July 2013, 03:51 PM   #15
DrDyna's Avatar
Well, I'd imagine that part of it is good 19mm baltic birch ply is probably double the cost of MDF, that's probably a major reason you don't see it more in commercial designs.
Now for something completely different, look at how Magico makes their cabinets O_O
Old 6th July 2013, 04:01 PM   #16
lanchile's Avatar
Wow, those speakers are very expensive! But it is kind of a contradiction there. Because He is using Metal rods to avoid resonance...and the worse material is ...metal! That is why metal speaker stands are suppose to be filled with sand to cancel the resonance. Metal is good for BELLS! Best material for speaker stands is wood or other material that will not resonate But,not metal...Why? again, because of the poor job to avoid resonances. but maybe I am wrong here hehehehe
PS: You want the best material that will NOT reflect the waves back to the drivers and Metal is extremely solid and will be like a satellite dish reflecting those standing waves back to the drivers. You want "cancelations" not reflections. Even if you put dumping material, it will not be the same.
Old 6th July 2013, 04:09 PM   #17
mr. doom is offline mr. doom  United States
Default Wrong.
No high end professional subwoofer box is manufactured with MDF.
It may be used for home/auto boxes where strength to weight is a low priority but the big boys use high quality baltic for big horns and dual 18 boxes that mortals can move without a forklift. It is stronger and holds up better to moisture which along with the dust is why I will not buy another sheet of MDF.
Arco used to be decent but the china ply from the box stores is mostly junk.
Old 6th July 2013, 04:25 PM   #18
lanchile's Avatar
Those HUGE speakers are used for DJ's in concerts etc. They do not use MDF because those speakers will weigh so much that you will need a machine to lift them. That is way some speakers are made of Polypropylene material and are very light.
Old 6th July 2013, 04:28 PM   #19
lanchile's Avatar
Polk Audio - Dynamic Balance Technolgy - YouTube
Old 6th July 2013, 04:53 PM   #20
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Partly that, and partly because if you clobber an edge (and it'll happen in about 10 seconds in a pro-audio environment when the boxes need to be moved) MDF will often suffer fairly terminal damage.
MDF is frequently used
a/ because it's cheap,
b/ because it's dimensionally stable, &
c/ aside from the ends, which are a royal PITA, it takes a very good finish.
If it's a choice of that or some duff quality ply, the MDF, which is usually more consistent than the cheaper plywoods, is unquestionably the better choice since it's not likely to fall apart. However, it is not without its problems, the big one being that it's not really stiff enough for most bass enclosures, if you're going all-out. There's a reason Avalon & some others (whatever you think of their speakers) use massively thick front baffles.
Based on the average MOE values, you need about 1 1/8in - 1 1/4in MDF to ~ equal the stiffness of 3/4in BB plywood. Since you can't eradicate panel resonance, just shunt it to somewhere it's less likely to be excited, that means going down, below the BW of the enclosure, or up, above it. The former is a swine with bass boxes; you need thicknesses with mass approaching a reasonable layer of concrete. Pushing them up, above the BW of the box, is usually somewhat easier. High stiffness (relatively) low mass, & fairly easy to damp out. There's no reason metal rods for additional panel-stiffening should cause any audible problems so long as some common sense is used in their placement & a little damping material added if required. Typically their resonant frequency will be well above the main box operating BW, where there is little energy available to excite them. This is fairly basic stuff; ask any mechanical engineer.
What Plywood are you buying?Hide this!Advertise here!
OSB vs Plywood Chris8sirhC Multi-Way 35 8th April 2014 06:27 PM
Question about plywood Moondog55 Multi-Way 34 31st May 2011 01:05 AM
Poplar plywood JC951t Full Range 2 6th January 2009 03:00 PM
Plywood not glueing well amo Multi-Way 7 17th July 2004 02:27 AM
Flexible plywood.... jonz Multi-Way 4 5th June 2004 10:11 PM
