First HT sub.
First HT sub.
Old 5th July 2013, 10:19 PM   #1
castlesteve is offline castlesteve  United States
Default First HT sub.
I am building a sub for a friend of mine who is putting in a home theatre. The room is 26/14/9 and he has installed Dayton in walls for a 5.1 system. I have a Dayton RS315HF-4 for the driver and a bash 300 amp. I need opinions on what size enclosure i should use to sound the best with his HT. Also would you go sealed or vented?
Old 7th July 2013, 08:41 PM   #2
Ok so it looks as if a vented 3-4 cu ft enclosure will be the best choice. I am going to use 2x3inch vents at about 17" each. Does this make sense?
Old 7th July 2013, 10:39 PM   #3
ODougbo is offline ODougbo  United States
Steve, did you check PE forum?
HT Subwoofer Doesn't Sound Right
Old 8th July 2013, 01:59 PM   #4
Michael Chua is offline Michael Chua  United States
Michael Chua's Avatar
3cuft is about right for vented. F3=23Hz
You can go for a 3cuft Closed Box if you don't mind a higher F3=36Hz.
ampslab
Old 9th July 2013, 07:33 PM   #5
Steve, how is your project going?
Old 10th July 2013, 03:47 PM   #6
Inductor is offline Inductor  Portugal
Inductor's Avatar
Hi, guys.
It's my first impression that Dayton Audio 12" woofer RSS315HF-4 is well adapted for a sealed sub enclosure with that mentioned amp. (Just as a side note the 400W max. can not take the woofer to max excursion in a BR that would need close to min. power ~900/1000W@4/3.6 Ohms). This combo amp+driver (sealed) is just perfect. I would probably start with a sealed ~100L/90L(QTC = 0.707) enclosure, as was referenced (85L) in the previous post.
100L = 3.5315ft³
85L = 3.0017ft³ (Michael Chua)
The VB ~120 L/FB ~ 22.0 Hz for a BR, low tunning frequency and monstrous enclosure (you have to add here to the net int. vol. all the space for the big vents and all) doesn't make it a good BR practical candidate, instead it's good performance and low F-3 dB=20 Hz. The problem is again is the power RMS needed for such a monster Pmin. 698.2 W@4.2 Ohms to 818.3 W@3.6 Ohms (22/164.3 Hz), for it's max.excursion, when 400W is the spec RMS and amp specs (Bash 300W) are "300 watts RMS @ 0.5% THD into 4 ohm load".
A quarter wave is also a great performer for this driver.
Old 10th July 2013, 11:54 PM   #8
Thanks for all the posts guys. I am starting the build this weekend and am going to do a 3.5cu ft ported with 2x3" ports. I am having a carpenter build the box as it is going to be disguised as an end table type thing and painted to match the existing cabinetry. I will post some pics when i have them.
Cheers.
Old 11th July 2013, 12:14 AM   #9
badman is offline badman  United States
badman's Avatar
Before you go too much further- has your friend considered infinite baffles?
Zalytron has their woofers on sale, the 1201PL is $99.... for a case of 12, solid 12" woofers. They would work nicely in an infinite baffle (in-wall) setup, with 8 of them, you would never be wanting for output or power handling.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 11th July 2013, 03:17 PM   #10
I am having a carpenter build the box ...
You may want to ensure the box is sufficiently braced and the joints are well sealed.
ampslab
First HT sub.Hide this!Advertise here!
For Sale: Goldpoint SA4 HT passive preamp with HT bypass Face Swap Meet 0 22nd January 2010 02:00 PM
Looking for Sub for my HT. samsagaz Subwoofers 0 8th January 2007 11:30 PM
Ht? sivan_and Everything Else 5 31st August 2006 08:33 PM
Ultimate HT sub? bhg41088 Multi-Way 15 11th April 2004 08:04 AM
HT without a HT receiver paulspencer Digital Source 28 12th December 2003 08:29 PM
Copyright ©1999-2017 diyAudio
