wiring up dvc subwoffers - diyAudio
Old 22nd June 2013, 05:02 AM   #1
Default wiring up dvc subwoffers
I have recently bought 2 pioneer 12" dvc subwoffer(4 ohm for each coil)
There are always 2 ways to wire them up as net 4 ohm load.
1) coils in series and woffers in parallel( (4+4) || (4+4) = 4)
2) coils in parallel woffers in series ( (4||4) + (4||4) = 4)
Will there be any difference in quality produced or not?
Old 22nd June 2013, 05:20 AM   #2
picowallspeaker's Avatar
Hi
4+4=8 series connection of two coils
4//4=2 parallel
so for 2 woofers paralleled coils then series connection it's 2+2=4
or // for each woofer so 2+2 series, still makes 4 Ω
Old 22nd June 2013, 05:29 AM   #3
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
The higher the resistance (numeric)
The more accurately will the coil move, not sure why but for me 8 ohm subs sounds worse then 4 ohm ones, maybe the only reason was my amp 20W at 2R 12V
Old 22nd June 2013, 05:34 AM   #4
i made mistake up there in calculations now they fine
Old 23rd June 2013, 11:24 AM   #5
chris661's Avatar
Really?
What makes this so?
Old 26th June 2013, 02:04 AM   #6
Inductor's Avatar
Originally Posted by chris661 View Post
Really?
What makes this so?
Maybe just the translation, I understand that there's more distortion, generally speaking, with lower impedances.
DVC Wiring Question 69stingray Multi-Way 3 6th April 2007 12:42 PM
DVC wiring questions 2litre Subwoofers 6 11th October 2006 11:56 PM
DVC wiring questions.. JRace Subwoofers 6 3rd March 2006 07:40 AM
Wiring a DVC with seperate sources Raoul Multi-Way 2 21st July 2004 09:29 AM
wiring a sub in parellel with DVC Hat-Rack Subwoofers 4 8th March 2002 12:15 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
