re TB Subwoofer design, phase concerns
Old 18th June 2013, 04:45 AM   #1
Thims is offline Thims  Australia
Default re TB Subwoofer design, phase concerns
Hello,
I have a room with a raised floor in which I wish to use 3 sub woofer enclosures using the TB W5-11338. I have only a height of 155mm to play with.
Each sub would have 4 x TB W5-1138 in a ported design.
Because of width restrictions on the front area, I cannot place all of the drivers in a straight line but can place them in a u shape with a port at the rear.
My concern is keeping all of the drivers in phase and with the port at the rear.
Each enclosure is approximately 48L with a tune of 37hz.
I normally use Leap but since upgrading to Windows 7, it doesn't work on it and I have not been able to test the design before I build it.
Can anyone see issues that I cannot see or if this design will work properly?
Or a better solution using different drivers? I could fit 3 LAT500 in there but I don't think they would have the same output as 12 TB's.
Old 20th June 2013, 06:21 PM   #2
kessito is offline kessito  Netherlands
try vmware player. it's free and woks great if you need to run old applications
cheers,
kees
Old 20th June 2013, 09:19 PM   #3
tb46 is offline tb46  United States
Hi Thims,
As long as you stay below ~100Hz you should be fine with that arrangement. It looks to me that your needs would be perfect for djk's PPSL:
http://www.diyaudio.com/forums/subwo...nclosures.html
I'll attach an example, the standard PPSL is on the left, the opening can be reduced to 1/2 Sd (or even a little less).
Oliver
Old 20th June 2013, 10:22 PM   #4
Hi again,
Have you noticed that this driver is not a 5-1/4" driver, but more like a 6-1/8" (frame O.D.) driver? Manufacturer's spec is 155.8+-0.5 mm.
What is the space you have available, e.g.: the front area, and the area looking down on the sub?
What are your output requirements/application?
Oliver
Old 23rd June 2013, 11:58 PM   #5
bentoronto is offline bentoronto  Canada
Can't say as I understand the question here, but why do you want to have similar/uniform subs when heterogeneity works a lot better in real rooms (even if wannabee-engineers recoil at the thought)?
Ben
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio
re TB Subwoofer design, phase concernsHide this!Advertise here!
phase splitter concerns ? coresta Tubes / Valves 13 1st May 2008 09:05 AM
anyone tried removing TB phase plugs? neutron7 Multi-Way 0 21st October 2007 07:06 PM
anyone removed phase plug from TB W3 871S neutron7 Full Range 1 16th January 2007 10:52 PM
john's tb - power handling concerns dvdwmth Multi-Way 8 1st September 2004 05:16 PM
Copyright ©1999-2017 diyAudio
