Low distortion, DSP based high gain servo controlled woofer controller.
Old 17th June 2013, 02:52 PM   #1
Tranquility Bass is offline Tranquility Bass  Australia
Tranquility Bass's Avatar
Default Low distortion, DSP based high gain servo controlled subwoofer controller.
This is a work in progress based on an initial prototype (REV:A) and nothing is set in concrete yet so Id thought Id share some of the preliminary results I have achieved thus far which look very promising.
I was going to put this in the subwoofer section except the main goal of this device is for accurate bass reproduction of music using a servo controlled woofer in a sealed box, open or infinite (large wall or floor mount) baffle systems. Typically it would be used as part of a multi-way passive or fully active speaker system or a stand-alone subwoofer system used to complement an existing full range speaker that cannot cover the bottom octaves. It has a fully programmable active crossover feature that can be used as a two-way stereo system with two dedicated bass servo channels. Alternatively it can be set up as a mono 3 or 4 way active system including one dedicated bass servo.
The board is designed to interface directly to a highly linear and low noise industrial grade accelerometer, namely a Measurement Specialties ACH-01-03 accelerometer. A novel mounting method directly couples the accelerometer to the voice coil which minimizes base strain and thermal coupling to the accelerometer. This accelerometer features an integral shielded flexible lead and a +/- 150g capability with a 30KHz mechanical resonance. This is the same accelerometer used in a $50,000 reference speaker system for the same type of application. It can be purchased from a number of sources including Digikey and Mouser for as little as $20.
A simple design procedure using fully automated measurement to characterize the speaker and box simplifies the entire design process without requiring any specialized or expensive equipment. No PhD required in electronics or electro-acoustics A servo woofer design can be implemented and operating in less than 30 minutes !!
Initial testing and measurements are promising with a maximum of 43 dB reduction in motor distortion achievable. Most commercial systems only provide between 6-12 dB reduction in THD.
Any questions and suggestions are welcome and any of the specifications are subject to change. I hope to make this thread a blog on my progress with this project so any feedback is welcome.
1st image - DSP servo controller,
2nd image - Test loudspeaker with accelerometer mounted to the voice coil,
3rd image - The whole setup,
4th image - Distortion results at 20Hz before feedback,
5th image - Distortion results at 20Hz after 30 dB feedback applied,
David
Old 17th June 2013, 03:20 PM   #2
Pano is offline Pano  United States
Pano's Avatar
Impressive results! You've even cleaned up some of the harmonics above 100Hz.
Would love to see a test frequency where the harmonics don't line up with the 50Hz mans.
Some 2 tone tests would be fun to see, as well.
Take the Speaker Voltage Test!
Old 17th June 2013, 03:52 PM   #3
I have some tests that I did at 15Hz that I will post tomorrow. Because this speaker is a car speaker its linearity is very bad below its resonant frequency which is about 30Hz. It has a lot of motor and suspension non linearity and probably a very limited X-max of 10mm or less. There is no flux shorting ring so it also has a lot of high frequency distortion as well. The drive current to produce all of the distortion was not very much which makes it ok for car use because only SPL matters in that application
However for the purposes of comparison of before and after it is the ideal test candidate. Also it can handle lots of power so mishaps are not going to kill it. Quite often I have driven the Power Physics 1000 watt amp into clipping when I was developing the DSP code
regards
David
Old 17th June 2013, 03:59 PM   #4
Pano's Avatar
Cool! It does look like the ideal test driver for what you are doing. Looking forward to seeing more results. Also very interested to see what your DSP will do once the speaker is mounted in an enclosure. Running before and after DSP sweeps with something like ARTA-Steps or HOLMImpulse would show how well the DSP feedback handles any problems coming from the box itself.
What the immediate goal? Will you be telling us enough about the system that we can build one ourselves?
Old 17th June 2013, 04:27 PM   #5
Yes it's aimed at diyers or OEMs etc who want to build high quality servo controlled (sub)woofers without requiring a PhD in electronics or electro-acoustics I have done all of the ground work for them and encapsulated it in the dsp hardware/software as well as providing a user friendly windows app that communicates with the board via a USB connector
Whether the speaker is mounted in a sealed enclosure or open baffle etc ultimately the whole package is designed to quickly measure, analyse and commission a complete servo controlled woofer system from start to finish without requiring any specialized or expensive test equipment. Also the design is not tied to a particular loudspeaker or amplifier vendor although it would be unwise to use a cheap speaker with a high resonant plastic cone etc. Whilst the servo can fix up motor problems it can't perform miracles on a poorly designed speaker with bad diaphragm vibration modes and resonances
However there are no need for special drivers with sensing coils that can only be purchased from the one source. Hopefully some driver manufacturers may jump on board and build the accelerometer into their speaker so they can add more value to their products since you can now buy these accelerometers off the shelf for less than $20 in one off quantities which is a bargain compared to what you would pay for the equivalent device 10 years ago. If not the diyer can still mount the accelerometer themselves just I have done on the prototype.
It's still early days yet and the dsp code is an ongoing concern but its all starting to converge to a final end point hopefully
I will post some more measurements tomorrow as I am not at my other computer at the moment.
P.S. The same accelerometer is used in a $50,000 reference speaker system for the same type of application. Hopefully my system gives much better performance
regards
David
Old 17th June 2013, 05:00 PM   #6
Barleywater is offline Barleywater  United States
Impressive indeed.
Does this enable speaker to make nice 20Hz square wave?
Old 17th June 2013, 06:44 PM   #7
Pano's Avatar
Thanks David.
FYI, that accelerometer is $38 at Mouser here in the USA. Not bad, and it may be a useful tool for all sorts of other things, like panel resonances.
Old 17th June 2013, 06:53 PM   #8
kessito is offline kessito  Netherlands
Interesing stuff, nice job!
What is theoretical upper frequency the device can "fix" based on accellerometer and samplerate/converter latency?
cheers,
Kees
Old 18th June 2013, 03:35 AM   #9
cheers,
Kees
Hello Kees
I run the ADC's and DAC's at the fastest rate of 192 KHz which minimizes total group delay to 7.5/fs or about 37.5 uS. Then add to that delay through the dsp processing and analog sections and you can expect about 4 degrees phase shift at 100Hz. Believe it or not most of the phase shift comes from the driver because above the piston range of the driver the diaphragm acts as a transmission line with many different vibration modes and exhibits a very complex impedance depending on how it is constructed and how it is terminated at the surround. This is why one vendor of servo systems uses drivers with rigid metal cones. I have an 8 inch driver with aluminium cone and I can confirm it performs much better than paper.
For stability reasons I purposely limit the maximum open loop gain bandwidth to 120Hz. Above this frequency, current feedback reduces high frequency distortion due to inductance modulation. Limiting the open loop gain bandwidth means I don't need to use drivers with special construction because the vibration modes will fall outside the bandwidth of the servo amplifier
I will post some more measurements.
regards
David
Old 18th June 2013, 03:49 AM   #10
Originally Posted by Pano View Post
Thanks David.
A few weeks ago Digikey had them for $20 whilst Mouser was $40 but now they have gone back up again. Bummer I should have bought a heap of them
regards
david
Low distortion, DSP based high gain servo controlled woofer controller.Hide this!Advertise here!
Passive Radiator for Low Excursion, Low Displacement & High Sens Woofer? goody75 Subwoofers 15 7th May 2012 09:07 PM
Low distortion & noise digitally controlled volume chip abraxalito Analog Line Level 6 13th August 2011 02:14 AM
Amazingly low distortion -- Radford-based design ray_moth Tubes / Valves 3 13th November 2010 03:30 PM
Low cost dsp based crossover module Crossoverman Multi-Way 38 20th February 2010 12:25 PM
Is there a no/gain preamplifier schematic using high-distortion EC90? Layberinthius Tubes / Valves 6 10th May 2004 07:13 AM
