SQ and stuffing
SQ and stuffing
Old 10th June 2013, 10:30 AM   #1
DAMIC is offline DAMIC  Seychelles
Default SQ and stuffing
I am in process of changing the drivers in my 2 vented subs with newer Visaton TIW 250 8 OHM units. The current boxes give me net volume of 65l, which I would like to increase to about 80l.
So, I have two options, first: to slightly modify/enlarge the current boxes to desirable volume with no stuffing at all, and second, to put determined amount of polyfill , that will imitate bigger volume.
The subs will go up to 84Hz (LR/24dB, by EV Dx34a digital x-o).
Ia am ok with any option, but wonder which one would give better sound quality , smaller volume with stuffing or bigger, without.
Thank you in advance for any opinion.
Old 12th June 2013, 02:52 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
SQ and stuffing
I would estimate you're not going realize the same advantage from stuffing as you would increasing the box size by almost 1/4. I understand the stuffing can add a 'virtual' 10% to the volume
planet10 needs your help:
Let's help Ruth and Dave
Old 13th June 2013, 08:33 AM   #3
Thank’s a lot Weldon, you are right. Yesterday, I find some older posts written by Sreten and Svante that lead me to the conclusion that there is no substitute for pure volume.
Virtual volume increase using wadding
regards,
SQ and stuffingHide this!Advertise here!
woofer sq back Multi-Way 27 22nd August 2012 10:11 AM
Best enclosure for SQ TheBassChild Subwoofers 6 17th October 2011 03:44 AM
I want the best SQ sub I can get for under $400 gadgeteer123 Subwoofers 30 29th January 2010 08:05 PM
Best Sq sub setup plenk Car Audio 7 21st June 2008 10:19 AM
Sq-5 gianis Tubes / Valves 0 11th January 2004 09:12 PM
