RCA Subwoofer problem
Old 5th December 2003, 01:45 AM   #1
soundNERD is offline soundNERD  United States
Default RCA Subwoofer problem
I have a RCA subwoofer I am fixing for somebody. It was given to me not working. It has a 200W amp, and a 12inch sub speaker. The amp worked fine, but the problem was the speaker. The negative input wire connecting to the cone from the input pins on the spaker had a bad connection. I soldered it, and finally got it to work. The impedence of the speaker is 4-ohm, and my DMM measured 4.5. when I wiggled the wire it would jump around from 4.5 to around 5.5 ohm. Is this bad for the amplifier? Would it be better to just buy a car sub from cirucit city or best buy and replace it? I do notice that the speaker rattles if turned too loud and don't know if it is the bad connection or bad speaker. It could be just do to the fact that RCA does stand for Really Crappy Appliances
Should I just buy a new speaker?
Old 5th December 2003, 01:54 AM   #2
Guss is offline Guss  Canada
Guss's Avatar
Don't worry about the imp, its always better not to get under the load tap...No dont buy another speaker, it wouldn't fit the box. If it rattle try remove some gain with the EQ directly on the bass amp.
Old 5th December 2003, 01:58 AM   #3
BAM is offline BAM
Send a message via AIM to BAM
(In case you're wondering what soundNERD means when he says the new woofer won't fit the box, consider this: There is more to a driver ditting in a box than the frame size. There are various electromechanical parameters that the woofer has, and the box is sized and tuned to those electromechanical parameters such that the driver delivers the flattest, most extended frequency response possible.)
Old 5th December 2003, 02:07 AM   #4
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
The speaker rattles when played too loud?
Maybe a rubbing voice coil? In that case, you would need a new speaker.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 6th December 2003, 01:13 AM   #5
I am pretty sure that RCA wouldn't spend too much time designing a perfectly tuned box. i mean, come on, its an RCA sub.
I didn't buy a new speaker yet. The thing is just that with the current one, when one of the wires connecting to the cone from the connection pins is jiggled, the resistance changes. I don't think that that is right. I was thinking that it might be better to just go and buy a new sub speaker.
About the rattling, I almost thought it was something like that, but is is a cheap speaker with a small magnet, so maybe it just can't go that loud. The speaker and the amp are tightened as tight as they were originally from the factory, so I am pretty sure it is the speaker.
RCA Subwoofer problemHide this!Advertise here!
Problem with my subwoofer tareqx2 Subwoofers 4 24th October 2008 01:57 AM
tube amp subwoofer hum problem timolien Tubes / Valves 3 13th September 2006 01:41 PM
subwoofer problem.HELP!! sachi Subwoofers 6 2nd March 2005 06:12 PM
Subwoofer distortion problem lordy Subwoofers 11 16th January 2004 02:43 AM
