Infra sonic subwoofer design
Old 16th May 2013, 12:11 AM   #21
opcom is offline opcom  United States
Originally Posted by opcom View Post
Thank you for correcting that misconception.
Here's the room. At "A" the 30-40Hz bass was not as loud or effective as at "B". What causes this?
The room is only a little smaller than the OP's room. Seems relevant.
Old 16th May 2013, 01:42 AM   #22
just a guy is offline just a guy  Canada
Usually uneven coverage at low frequency is due to modal activity. There are room mode calculators online but they are very simple. For precise answers you would need to provide info about construction materials (rigidity), leakage (doorways, cracks, HVAC holes) and a precise layout (taking into account the overall dimensions of the group of rooms and the boundaries and doorways between them) and absorbtion (furniture, carpeting, etc), among other things. In other words, it's currently impossible to map out response accurately at any given spot in a room but if the room booms it's probably caused by standing waves.
Old 16th May 2013, 11:52 AM   #23
Inductor is offline Inductor  Portugal
Inductor's Avatar
(--^) For small-room acoustics use LISA. Free/Affordable Finite Element Analysis Software.
Old 16th May 2013, 12:14 PM   #24
Inductor's Avatar
Alex, it helps to know your flag/country for future resources.
The driver posted by just a guy on post #18 will need (each) an enclosure of 300/350L and amp of 2000/2200W@4Ohms. Have you decided your project directions?
Stereo Integrity HT 18" Subwoofer
Old 16th May 2013, 12:49 PM   #25
No, the SI 18 doesn't need anywhere near that much space and can't handle even close to that amount of power.
If used in IB you can fit 5 drivers on an 18 inch cube manifold. You can increase the depth of the manifold and fit more drivers per manifold if you don't mind keeping the low pass crossover relatively low. Or just use more manifolds. Even in a sealed box you can go as low as 4 cubic feet, lots of people do it.
As for power, these are rated at 600 watts rms and I wouldn't push it too far past that. They have a tiny 2.5 inch voice coil and they will burn if you get too aggressive. (They are fairly new and I've seen reports of burned voice coils from experienced users.)
Old 16th May 2013, 03:30 PM   #26
tittualex is offline tittualex  India
Dear all ,
thanks for all your comments... forgive me if i am going a little too ahead.... But I have a doubt... if iam going to use conventional 18" drivers ... what type of enclosure will help me to achieve the best result in reaching the mark of 10Hz. or below ? taking the room to be a rectangle with (18' x 10'x 10') , with plain concrete walls and one door which may not be perfectly airtight......
regards,
Alex
Old 16th May 2013, 03:39 PM   #27
IB or sealed will yield the smallest enclosures. Any type of box that uses resonance (ported, tl, any type of horn) will have to be large to get to 10 hz or below.
If the room is concrete IB may not be possible.
Old 16th May 2013, 03:44 PM   #28
Here's an idea for sealed boxes for the SI 18 woofer.
4 cu ft Subwoofer box - Subwoofer Flat Packs DIY Sound Group
Shipping costs would be prohibitive to India but you can make your own.
Your room is fairly small and quite rigid if it's concrete, and probably airtight enough, so 2 or maybe 4 of the SI 18 woofers should be enough, depending on how low you want to go and how loud you want it to be.
Old 16th May 2013, 04:40 PM   #29
weltersys is offline weltersys  United States
weltersys's Avatar
Back in the late 1970's Anicom Sound in Minneapolis used to use a large sealed cabinet called the "Futz" which had 4 drivers on a triangular manifold, three on the sides, one in the back.
The rear driver consistently was ruptured while the other three never had any problems.
There are tougher cones now (the Futz used JBL 15" woofers) but I still would not put a single cone in the back space of a manifold, even if it would not tear up the cone, it would probably add distortion.
Old 16th May 2013, 04:53 PM   #30
I'm having trouble imagining this layout. A quick search didn't lead to any pics of this creation. Are you saying the manifold exit was at the peak of the triangle (like a pyramid)? If so that's an extremely odd layout and I'm not sure why the manifold exit would be made smaller than the cross sectional area where the woofers mount.
Maybe I'm not imagining it right, but any type of triangular manifold sounds very odd and a very bad idea.
Anyway, afaik only pressure can rupture cones and there shouldn't be any pressure worth noting in a 5 driver IB manifold with a consistent cross sectional area and an exit equal to the cross sectional area. Using a smaller sealed box would be different, that could generate extreme pressures.
I can't imagine why the 5th driver would add distortion. It wouldn't have the benefit of opposed forces that the other 4 drivers have but that's not adding distortion, it's just not benefiting from reduced opposed forces distortion.
Infra sonic subwoofer designHide this!Advertise here!
What is the sonic result of this crossover design corelement Multi-Way 26 22nd August 2012 10:43 PM
Adding Subwoofer output to Sonic T-Amp HolyGhostFire20 Class D 4 23rd November 2011 07:33 PM
Help needed for Sub-sonic subwoofer design.... orangealpaca Subwoofers 52 3rd May 2008 12:23 PM
Driving a subwoofer with a sonic t-amp flashbacck Class D 3 28th January 2006 01:02 AM
