okay im going to build a rack in my van for work... - diyAudio
Old 13th May 2013, 01:25 AM   #1
Default okay im going to build a rack in my van for work...
This being the case i'm going to incorporate a sub enclosure into the part i wouldnt be able to reach easily.
the space available is 18"h x 15"d x 48"w
requirements
2.0pi flat to 20hz, i listen to alot of music wich requires cone control to 20 hz and output there.
.5pi output to 120 db, its in a van so i expect a 12db/octave boost below approx 100 hz due to transfer function.
id like to keep the amp small so around <250w would be great.
A tapped pipe or horn, NO PORTED OR SEALED WITH EQ PLEASE, BEEN THERE DONE THAT GOT THE T-SHIRT SOLD IT ON E-BAY, NO WIGGLE ROOM HERE. I have this room to use so I'm going to use it.
I want to order the driver from parts express so that's the only place to look, buyouts or whatever.
if you want i have hornresp and don't mind doing some tooling around if you want to drop a driver model your familiar with on me.
Driver budget up to $100 plus shipping.
Altec Lansig computer speaker amp, Paradigm atomss, Altec computer sub, Windows PC source
Old 13th May 2013, 01:31 AM   #2
TundraLTD's Avatar
So you're asking anyone here to do all the work for you? or what exactly are you asking?
Old 13th May 2013, 02:40 AM   #3
id like to start a thread where people throw ides at me.
Ive read lots on here and havent seen anything that fits my specific parameters.
i understand how to use hornresp, however cant post results yet if anyone can help that way.
Old 13th May 2013, 02:40 AM   #4
Pretty sure you should do a properly designed long excursion 10" or 12", PORTED, in that box size to get that kind of extension.
Old 13th May 2013, 02:55 AM   #5
ok, so i want to post an image of some noodling im doing, any assistance there appreciated
Old 13th May 2013, 03:02 AM   #6
TundraLTD's Avatar
the image(s) must be hosted on the internet. does your ISP give you storage space or do you have a dropbox or similar online storage account
Old 13th May 2013, 03:21 AM   #7
id prob use an online service
Old 17th May 2013, 03:28 AM   #8
got myself an SDX10 today, been tooling around in hornresp, can someone post a screenie of a vented box input screen in horn resp any one will do ijust want to see te layout of inputs
Old 17th May 2013, 04:24 AM   #9
TundraLTD's Avatar
Start HERE
It is a relatively simple to use program and very powerful tool.
Old 17th May 2013, 04:26 AM   #10
TundraLTD's Avatar
This is the box recommended in their PDF
Build your own stereo rack! Sir Trefor Construction Tips 26 25th March 2017 01:03 PM
Zigmahornet build- Help im new tigh4life Full Range 44 28th January 2009 04:37 AM
Im BAAAACK! Marathon amplifier question, won't work bridged mono! 240z4u Car Audio 11 3rd April 2008 02:56 AM
Im gona build a gaiinecloone.. preamp qs! fusion Chip Amps 1 22nd January 2008 07:31 AM
Copyright 1999-2017 diyAudio
