Passive Radiator vs Open Baffle Bass - Page 2 - diyAudio
Old 14th May 2013, 11:41 PM   #11
diyAudio Member RIP
An 18" bass + 2x18" PR's to be used above a subwoofer is seriously
OTT stuff, probably pointless and not thought through seems to me.
Just converting the the OB to a sealed box (about half the volume
of the PR box) would give you oodles more bass and low bass SPL.
I cannot see any scenario for PR's above a lower bass subwoofer,
transient response and integration will be poor. Parallel with the
PR's tuned deep and tight is a different matter. That could work
well with music with the sub off and then add the sub for AV.
rgds, sreten.
Old 15th May 2013, 01:52 AM   #12
Here is the thinking behind it. Geddes advocates the use of a three sub mixture with all subs not necessarily being the same, or covering the same frequencies for movies to create a fog of sub frequencies.
The left and right Pro 5100 subs / lower bass (with 2 x PR in each) have a higher efficiency then the Ultra LMS 5400 lower frequency sub, which means I could for the biggest part use only the Pro 5100s off a smaller amp for both music and movies. When the movie requires seriously low bass fire up the LMS 5400 sub. If the Pro 5100s were tuned for higher frequencies (i.e. not adding a lot of weight to the PR) I thought it might integrate better into an active 4 way system.
Should that fail I could tune the Pro 5100s lower and add some cheaper OB woofers back into the mix, that are better suited to OB, while the TC Sounds are great drivers, and sound fantastic, they are not really well suited to OB with their low QTS.
Also buying just the two PRs at this point, if the Pro 5100 don't work well in the desired arrangement, I can merely slip the Ultra LMS 5400 into the box I build and use it for deep sub. So either way I am going to wind up using them.
Jamo R909 Passive Open Baffle Project josephpo Multi-Way 69 12th August 2012 04:58 PM
Open Baffle Bass kctess5 Multi-Way 21 10th February 2012 10:54 AM
Passive radiator for bass guitar? juliewarden Instruments and Amps 15 20th September 2010 03:54 PM
Passive radiator use in bass trap? roland bios Multi-Way 16 29th December 2006 02:24 AM
Copyright 1999-2017 diyAudio
