Subwoofer project using a 12" Peerless 835017 (or better)
Old 15th May 2013, 10:38 PM   #11
shmb is offline shmb  Australia
Ok, thanks, so it looks like a single 4.5" diameter or more is required.
Looking at the simulations, the ideal tuning frequency would probably be anywhere between 19-22Hz??
Parts Express sells 4" and 6" dia dual flared ports, but 6" port lengths will be impractical. I would need an elbow. (if I can fine one for that size)
Is this an issue with regards to port noise etc?
Any ideas of who else sell these sorts of things?
Thanks.
Old 16th May 2013, 03:51 AM   #12
Inductor is offline Inductor  Portugal
Inductor's Avatar
You can resource a PVC tube (construction, other) for loudspeaker ports locally. If using the 4" from PE you can use/test it's max. length of 17".
Precision Port 4" Flared Port Tube Kit 268-352
4" flared speaker ports - DIY Audio & Electronics - StereoNET Australia
Commercial Port Flares
Old 16th May 2013, 04:01 AM   #13
Inductor's Avatar
You can make also a rectangular flared port with the same wood you are using in one of the sides of the box.
If the port is not directed to you (to your face), you will have less noise problems, only at max SPL.
Only use bends if not enough space for straight ports.
RAM Designs: Step by Step Ported Subwoofer Box Design - YouTube
Old 16th May 2013, 04:10 PM   #14
Shadydave is offline Shadydave  United States
Default long round flared ports
I bought an extra PE 4" port kit and used the couplers along with the tube cut in half to make a pair of 24" long ports
It sounded a little boomy, or maybe had allot of group delay.
And there are L/D limits that supposedly should be followed and the quoted audiophile (Length / Diameter) limit that I have heard is something like 2 or 2-1/2 meaning that a 4" ID port should only be 10" long.
I do not know how much there is to this rule of thumb, but I think my 24" port was too long.
I finally took it out, sealed the boxes, made them into the main woofers and replaced them with proper subs with flared shelf ports.
Dave
Old 17th May 2013, 01:31 PM   #15
Ok interesting, about the diameter vs length limit.
Maybe someone else could explain if that is or isn't the case???
I think I'd still prefer to stick with the round 'flared on both ends' ports.
Anyway I'm still investigating for now.
Thanks.
Old 17th May 2013, 01:53 PM   #16
chris661 is offline chris661  United Kingdom
chris661's Avatar
Thanks.
The 2.5 rule is probably to do with port resonances: simulate a ported box in Hornresp and note the additional peaks and dips >100Hz.
If a port gets too long, you start to get resonances within the pass band of the subwoofer, which can prove interesting to integrate with other speakers
Chris
Old 17th May 2013, 04:15 PM   #17
Default Flare shape
One problem with commercial flared ports is they have a spherical radius on their ends.
While this looks good, at higher flows there will be flow separation causing the port to flow less than the nominal (4") diameter.
It would be better to have a flare shaped more like a funnel. with straight sides rather than sides that exponentially curve more and more.
The spherical radius port does work better at lower SPL's, it is when you crank it up and get higher velocities that the flow separation and hence turbulence in the port exit occurs.
Dave
Old 18th May 2013, 01:17 PM   #18
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi,FYI:
Here is another late suggestion for a Sub using the Peerless-835017 Driver:
b
Old 21st May 2013, 01:58 AM   #19
That may be a little big.
Anyway, the size/volume is now finalised, I'll end up with about 118-119L with everything fitted except port(s)
The volume of those still need to be subtracted so it depends on what size ports I use.
Looking at all the compromises, it seems I should go for the 4" dual flared port. Precision Port 4" Flared Port Tube Kit 268-352
It would be approx 40cm long. That will reduce the effective volume to about 114-115L.
Now on WinISD from my simulations, it seems that at 175 watts (the drivers RMS rating), port air velocity is about 30-31m/s at around 20Hz with the 4" port. (worst case at 175w)
Is this reasonable and acceptable?
This calculator from earlier in this thread: mh-audio.nl - Home tells me at least 11.5 cm diameter is required.
So will the 4" flared be enough in practice?
Thanks.
Old 21st May 2013, 04:45 AM   #20
Inductor's Avatar
Thanks.
You must be an engineer.
Read my post, you can't have max. power at Xmax. This was the suject of discussion in other threads (read SI 18"). You blow the woofer before you get max elongation...
Peerless 835017 XXLS 12"
Nominal Power RMS 120W
http://www.tymphany.com/files/XXLS-P...0Rev%201_0.pdf
2 examples for this project:
a) 115L/21Hz (38.84cm = 15 19⁄64in)
To go to max elongation you would need double the power more close to 300W@3Ohms.
b) For VB = 110.0 L, FB = 20.5 Hz, length (43.34cm = 17 1⁄16in).
You would need Pmin. 308.0 W@3.1 Ohms@20.5 Hz for max elongation (12.3mm/V=31.13 V) so don't worry (be happy) about max power output before you will blow the sub.
note. dB for max. SPL is unachievable by all standards so you will have a relative power off less than half or about that at a percentage of time you have max. volume in your system.
Subwoofer project using a 12" Peerless 835017 (or better)Hide this!Advertise here!
Dual 12" Subwoofer Project ReTrO Subwoofers 79 3rd May 2014 07:57 AM
FS: Dayton Reference Subwoofer RSS315HF-4 12" Subwoofer Driver matevana Swap Meet 0 12th February 2012 02:42 PM
Opinions Wanted on Dual 12" Subwoofer Project Sithlord2007 Subwoofers 20 19th September 2008 04:46 AM
Peerless India: Anyone need 12" subwoofer driver? yusuf Parts 0 10th January 2007 09:48 AM
Need a replacement 12" subwoofer driver chevy1965usa Subwoofers 0 26th December 2006 03:38 AM
Copyright ©1999-2017 diyAudio
