latest study in excess
Old 21st October 2013, 07:49 PM   #131
epa is offline epa  Netherlands
Originally Posted by epa View Post
looks real good,nice job
btw you might want to delay the outer subs a bit,for better dispersion of the upper bass.
uhrm its exactly opposite front sub needs the delay, if any
but it needs some experimenting .
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 22nd October 2013, 03:29 PM   #132
turbodawg is offline turbodawg
How do they integrate with tops in the midbass, and do the tops even come close to keeping up with them....?
Old 22nd October 2013, 05:31 PM   #133
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by Trackzilla View Post
weltersys- I am looking forward to having a chance to do some final tweaking & measurements, looks like it'll be a few weeks til I get caught up enough. BTW, distortion measurements haven't been part of my normal procedure, and they should be...any suggestions for a process on a tight budget?
Distortion testing is easy with some measurement systems, but still can be done the hard way by looking at a sine wave signal and the resultant harmonics on an RTA, subtracting the difference in dB, then calculating the distortion percentage.
For " close enough for rock and roll" purpose I calculated distortion % on the calculator page below, the harmonic with the highest level pretty much determines THD, the contributions added by lower harmonics generally add only a fraction of a percent to the highest harmonic.
In the two examples below a Lab 2x12" push-pull bass reflex enclosure is compared to a Lab 2x12" Keystone tapped horn using a 49 volt sine wave input at 35 Hz and 50 Hz.
At 35 Hz, the push-pull (PP) third harmonic (105 Hz) is 20.9 dB below the 107.9 dB fundamental, around 8.9% distortion, the tapped horn (Key) second harmonic (70 Hz) is 30.5 dB below the 114.5 dB fundamental, around 3.2% distortion.
At 50 Hz, the push-pull (PP) third harmonic (150 Hz) is 22 dB below the 109 dB fundamental, around 8% distortion, the tapped horn (Key) second harmonic (100 Hz) is 16.4 dB below the 119.8 dB fundamental, around 15% distortion.
The difference in distortion at high drive levels gives different sub designs quite a different sound, even when equalized the same.
In post # 12 the distortion and output of Lab 12 and a BC18SW115-4 are compared in the same cabinet:
Keystone Sub Using 18, 15, & 12 Inch Speakers
When doing sine wave testing like this you must keep the individual tests short and allow time for cooling between each test, the higher drive levels I used would burn the voice coils if applied for extended time periods.
Art
Old 23rd October 2013, 01:32 AM   #134
Trackzilla is offline Trackzilla  United States
Thanks Art, that's intuitive enough that I should be able to zap off some useful data about distortion when I get a chance to tune & test.
Old 23rd October 2013, 05:11 PM   #135
MemX is offline MemX  United Kingdom
Thank you for those graphs, they look like a good illustration of the distortion differences of Push-Pull setups
Old 24th October 2013, 04:55 PM   #136
weltersys's Avatar
Cool, as a suggestion type up all the frequencies and voltage you plan to test prior so you can copy and paste them in as you go, and keep track of where you are.
The only time I burnt a speaker during distortion testing was when I was manually entering, made a mistake, deleted, re-entered, oops...
Although this way of testing is a PITA, it does show more information than the usual distortion tests which only show second and third harmonics- some times even the fourth or fifth harmonic can be objectionable, since they show up where our hearing is far more sensitive than in the LF range.
Art
latest study in excessHide this!Advertise here!
Help! I've got an excess gain problem! MartinHyde Solid State 4 1st April 2012 01:06 PM
Excess Audio Test Equipment 1audio Swap Meet 5 29th September 2011 10:13 AM
Excess stuff for sale Tristanc1 Swap Meet 1 22nd August 2008 09:11 PM
Monday Night Excess kelticwizard The Lounge 0 1st October 2006 09:42 AM
Excess stuffs for sale PatPet Swap Meet 2 27th March 2005 10:09 PM
