jbl 2245h amplified by F4
Old 20th April 2013, 11:05 PM   #1
rosario is offline rosario  Romania
Default jbl 2245h amplified by F4
Hello people i want to ask if anybody know if nelson pass F4 in bridge can be the amplifier for jbl 2245h without an preamplifier ? I put the 2245h in open baffle and i guess the F4 doesn't have enough power or this 2245h must need an enclosure to sound?
Thx for reply's , greetings from Romania.
Old 20th April 2013, 11:27 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
no need for preamplifier ........ if you are having potent source
what power you need generally for that speaker ?
then we can calc backwards what voltage swing you need
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 21st April 2013, 12:24 AM   #3
I have yamaha da202 dac but in the future i want to use this dac to split signal to the F4 and also to aleph j. i want to use the F4 for 2245h and aleph j for jbl L16 decade speakers and bx63a crossover clone between dac and F4. is a good idea?
Old 21st April 2013, 01:14 AM   #4
Zen Mod's Avatar
F4 is not having voltage gain
Old 21st April 2013, 06:40 AM   #5
i need to make an preamp for it in this cause? can i modified the bx63a to have some voltage?
Old 21st April 2013, 11:27 AM   #6
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Hi rosario,
Here is an idea:
b
Old 21st April 2013, 12:26 PM   #7
scholl is offline scholl  United States
Default subamp
Not sure how the F4 would drive that woofer. You'll have to try it to find out. Odviously you like low power amplifiers. In applications like this sometimes more power and damping sound better than a sweet little amp. As well all know synergy comes in all forms. YMMV
Old 21st April 2013, 01:16 PM   #8
On Hiatus
SY's Avatar
Given the low Qts, this is not a particularly good speaker for open baffle without a lot of EQ.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 21st April 2013, 09:56 PM   #9
thx bjorno for this schematic , i tested in open baffle but it will have a enclosure. another thing about bx63a can i make the output balanced even the input to have some decibels more, it worth?
Old 22nd April 2013, 03:07 PM   #10
Agree, The driver is not well suited for an OB..What size and type of Box are you planning?
Regarding the Amplifier question:
Of course you can design a balanced output low Ohm buffer as you gain the double Voltage swing to feed the F4 but there would be an insertion loss at the F4 Receiver end if not made 'higher Ohmic' balanced to single end.
This is not a problem if you design a balanced input circuit using an Op-Amp like the already used TL07X amps in differential mode.
b
jbl 2245h amplified by F4Hide this!Advertise here!
WANTED JBL 2118h and 2245h mclsound Swap Meet 2 3rd September 2012 12:41 PM
JBL 4842 Subwoofer double 18" 2245H drawings for DIY? Niklas Madden Subwoofers 5 2nd July 2012 06:07 PM
JBL 518S amplified subwoofer system PhantomBox Solid State 0 13th April 2010 10:57 PM
JBL L100 Century & 2245H For Sale macka Swap Meet 1 10th January 2010 02:41 PM
JBL 2245H 18" Speakers on Ebay Bill Fitzpatrick Multi-Way 7 2nd August 2005 03:52 PM
