Newbie needs help with a manual/tutorial on DSP use - diyAudio
Old 8th April 2013, 12:48 PM   #1
Default Newbie needs help with a manual/tutorial on DSP use
Hello All
I am using the AllDSP 'AllControl' program. I believe my module is the AllDSP 1800.
I can't find a manual on what all the buttons on the control panel do.
I am 52, and a slow learner (too much red wine).
Help!!!.
1) How do I eq. the lowest octaves?.
2) If my woofers are side firing, and my mids and tweeters are 1st order x-over, what should a starting point be for 'phase'? on the 15" woofers.
Old 8th April 2013, 05:05 PM   #2
Originally Posted by Cousin Billy View Post
Hello All
Help!!!.
1) By ear, or with a measurement system.
2) To find actual "phase" requires a measurement system.
The starting point for aligning the phase between the mids and the woofers would be having them both "pushing" in the same polarity, that is, positive voltage to the positive terminal makes the cones go away (out) from the cabinet front.
Polarity can be easily determined with a battery touching the speaker wire.
Old 9th April 2013, 12:06 AM   #3
Thank you welter.
I found out that;
1) In the control panel, go to 'out1, than out 2' and choose "low shelf" and adjust. I do have a measuring system.
2) For phase, measure, adjust, measure, adjust, and more M & A.
Foo Dsp Xover tutorial pdelorme PC Based 1 30th July 2012 04:40 PM
RS-232 cable for DSP-Amp Digisynthetic DSP-1400 Sabbelbacke Parts 0 9th May 2009 10:33 AM
Looking for a tutorial? Carcano Chip Amps 6 3rd October 2006 06:50 AM
Yamaha DSP-E300 Service Manual? Stocker Everything Else 1 17th January 2006 06:10 PM
Copyright 1999-2017 diyAudio
