Single 21" or dual 18"
Old 6th April 2013, 06:52 AM   #11
abcdmku is offline abcdmku  United States
j.michael droke, I gave both speakers 40v. Then played sine waves at 20,30,40,50,70, and 100Hz. I'd say the "21" (2985) 50hz to 100hz 102.5+-0.5db" is more of 99dB. I think the dual 2954's lower resistance gives it the edge.
bentoronto, That was my initial fear of getting the 21", but they do use a rather beefy cone.
Old 6th April 2013, 02:15 PM   #12
bentoronto is offline bentoronto  Canada
Hate to seem churlish after you've bought driver but I think this forum should record ideas for the future too.
Sure, you can make a cone out of strong stuff but the various trade-offs of resonant freq, weight, motor, stiffness, etc. lead me to a rough preliminary impression that 15 or 12 inches is biggest-optimum, today, maybe. I also believe you gotta start with a resonance down near 20 and that is "line in the sand" for bass; hard to make a driver suspension and cone weight combo that achieves that for a big driver.
With the advance of technology, maybe 18 and 21 really are better than I imagine today or in the near future.
Ben
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and working on a folded 18-foot Voigt pipe)
Old 6th April 2013, 06:52 PM   #13
OscarS is offline OscarS  United States
unless you log the voltage going into each speaker, together with the impedance curve to see the resistance at one particular frequency, you don't really know if you're feeding them the same power. Even then, it could easily be attributed to alignment differences, as you can't possibly have the same exact alignment for both considering one has dual drivers.
..and that monkey business of "doubling Xmax"? what for? Just to use the P-P version of Xmax? Quantitatively, that sort of thing is useless for when you just want to compare relative swept volume. Sd * Xmax is enough (assuming MCMs specs are correct, which they are likely not). One Vd divided by the other is enough to compare them on a percentage basis.
Old 7th April 2013, 05:17 AM   #14
I know I didn't have to double the Xmax, but the cone moves two ways. Therefore I doubled it.
The reason I gave both speakers the same voltage is because I wanted the power to be relative to the amp, not the speaker. If the speaker is exactly 4 ohms it would then get 200w at 40v, whereas if the speaker is 8ohm it will only get 100w. If that amp can do 80v then in regards to the amp it is only at 50%.
I know that isn't the normal way to test speakers, but for what I'm doing it is relevant. I did do a test where both speakers got 10w, 50w, then 300w. The dual 18's where still louder for all three.
Old 7th April 2013, 08:21 AM   #15
Arty is offline Arty
hmm.... intresting test but if you do not mind, its pointless.
with these drivers, at least.
none of them are realy subs to be honest. anything that starts to fall at 50-ish hz is a medicore bass unit.
i would choose 2 smaller drivers, the motoric power vs mass to move ratio would be better.
smaller cones have a better stiffnes than larger ones.
but, interference between 2 cones makes 100% summing of them impossible.
Old 8th April 2013, 04:13 PM   #16
Shadydave is offline Shadydave  United States
abcdmku,
Power = E^2/R
where:
E = voltage
R = impedance
So 40 * 40 = 1600/4 ohms = 400 Watts
or
40*40 = 1600/8 ohms = 200 Watts
best to start off correct,
dave
Old 9th April 2013, 04:23 AM   #17
Single 21" or dual 18"Hide this!Advertise here!
Dual 18" Horn! abcdmku Subwoofers 7 12th June 2014 09:38 AM
Ripole subs with dual 21" woofers elac310 Subwoofers 4 30th January 2013 08:33 PM
Scaling up the SS15 for an 18" driver and other compact 18" designs col Subwoofers 32 23rd January 2012 10:17 PM
couple of questions on a custom single 18" pa sub staxx Subwoofers 9 31st October 2011 03:22 PM
Foster 12" Woofer Ripole sub: single dual driver unit or dual single driver units? IG81 Multi-Way 3 4th February 2010 02:48 AM
