FTRCelestion FTR15-4080FD and THAM-15 - Page 3 - diyAudio
Old 4th April 2013, 02:25 AM   #21
djk is offline djk
djk's Avatar
"Since you haven't showed any impedance plot, I can only judge by using Re. Those values suggest that all three drivers have a 'nominal' of 8 Ohms"
You're still missing the point.
Pick the lower efficency driver with the high x-max for a bass horn.
Candidates for the Darwin Award should not read this author.
Old 4th April 2013, 04:57 AM   #22
Originally Posted by PASC View Post
Hi!
Quote
By that, I simply mean that, given that some people have been reasonably happy with the 15PS100 in the THAM-15, that I would probably be reasonably happy with the Celestion. Or, said differently, that any difference between the Celestion and the 15PS100 will be marginal at best?
Unquote.
No experience with the 15PS100, but with 12PS100 which performs very well in the TH12 when you can beside use it till Pe, the performance of a bass guitar notes played thru the TH are also well defined from 40 to 100Hz, without overexcursion issues, and without any cone correction (impressive as THs suffer from overexcursion ill at Pe).
This performance (defined notes) isn't achieved by much drivers. To me it's a try and error thing beside parameters.
As the 15PS100 apparently has the same motor why not try one.
NB: Build 4 THAM15, sold two and two remain here unused. Tried several drivers innit. To me lacks lows.
Thanks for the input. The main reason for comparison to the 15PS100 is that it seems that the Celestion FD is somewhat similar. As it stands now I'm planning to send the Celestions that I have back later this week and at that point I can select any driver, or even a different design.
My preference for the THAM15 is simply that several people have been very positive about it, particularly with respect to the extension below 50hz, and also, I like the dimensions.
In fact, I think that it was this thread that discusses the TH12 that triggered my choice.
http://forum.speakerplans.com/fth12-...675_page1.html
Is this the "TH12" that you're talking about? As near as I can tell, the design isn't available, it's just a kit, is that correct? Interestingly, Tony originally called for the 12" version of the HDX in that cabinet.
Old 4th April 2013, 04:03 PM   #23
PASC is offline PASC  Brazil
Hi!
Not that one TH12. Look at the frequency response at page 1; to me f3 at 50Hz and f10 at 45Hz.
Remember iron law. You got portability but the price is extension down.
The 12PS100 is strong as a tank, but to me defined response thru all the gap it will be usable is what count, despite it's a bit less SPL.
Using now a few years B&C and 18 Sound drivers can say that they are in general top in quality. Use the correct one into your project.
Maybe the 15NW100 is the right candidate to habit your TH.
PASC
Old 4th April 2013, 05:16 PM   #24
Hi!
I don't mean to sound dense, but I cannot seem to find the TH12 design. I know of the FTH12 and the THAM12. AFAIK, the FTH12 design is also not available.
tnx,
gs
Old 5th April 2013, 01:50 AM   #25
If then I understand correctly, and my google foo is up to snuff, you're talking about what is referred to as the stapier design reduced from 680mm to 380mm in width?
If so, it doesn't sim very well for me assuming that I have the parameters correct. What driver are you using, 12PS100?
By this, do you mean how it sounds, or that it has a wide response in a TH? At any rate, it's not all that clear to me that I really get what aspsects of a driver will impact how it sounds to me.
So to be clear, are you recommending the PS100 series over the TBX100 series?
tnx,
gs
Old 5th April 2013, 01:44 PM   #26
Hi!
The 12PS100 is strong as a tank and to me defined response thru all the gap it will be usable is what count, despite it's a bit less SPL.
That's my findings.
Search, try and make your choices.
Good luck!
PASC
Old 5th April 2013, 05:07 PM   #27
Hi!
That's my findings.
Yes, it's just not clear to me what you're saying. I understand "strong as a tank", but what do you mean by "defined response through all the gap" ?
At any rate, thanks for your help.
Old 5th April 2013, 06:25 PM   #28
Hi!
"the performance of a bass guitar notes played thru the TH are also well defined from 40 to 100Hz"
Take the instrument, bass guitar, play the notes from the lowest to the highest
in the gap like 40/100Hz, first without any amplification, to make shure you have the backround and then amp it playing thru the speaker, and you will notice if it reproduces what you here first.
Only a few I hear do it well in the upper range.
PASC
Old 8th April 2013, 02:31 PM   #29
Hi!
I see, so, in a sense, you're talking about faithful reproduction through the passband, I hesitate to say flat, but, AFAIK, most of what makes a bass guitar sound the way that it does is due to harmonics. What attributes of the driver matter here?
SS15 or Tham 15? JohnnyPyro Subwoofers 44 6th January 2015 08:17 PM
Any videos of SS15, Xoc1 TH18, or THAM 15? jaysinet Subwoofers 33 6th May 2014 01:41 PM
Anyone have info, comments, experience with the RE XXX 15 VS TC Sounds LMS-r 15? SpinMonster Subwoofers 7 2nd May 2012 04:52 PM
Is LM3875 better tham LM3876 goldyrathore Solid State 12 12th July 2005 09:53 PM
For Sale: One TC Sounds HE-15 cube (similar to Stryke Power 15) Phloodpants Swap Meet 1 7th May 2001 11:44 PM
Copyright 1999-2017 diyAudio
