Procella P10/P15 Clones? Procella P10/P15 Clones? - diyAudio
Old 18th March 2013, 10:45 PM   #1
ReTrO is offline ReTrO  England
ReTrO's Avatar
Default Procella P10/P15 Clones?
It has been a while since I last posted on here, during which time I have finally boxed up my Audio Drive 12" drivers into BK Monolith (passive) cabinets and currently running a BK XLS200.
However due to living room constraints I would like to try and achieve a 'slim' subwoofer that would be somewhere between the Procella P10 and P15, i.e. using a pair of 12" active drivers. I have initially thought, ahh 2 x XXLS 12", but I don't think that will work too well. Maybe 1 active and a PR?
Looking at using a BL BSBPV500 amplifier to drive it/them.
Thoughts?
Procella Audio Subwoofers
Richard Wilson
Old 19th March 2013, 04:44 AM   #2
Inductor is offline Inductor  Portugal
Inductor's Avatar
Procella P10:
Dual long-throw 10” drivers with 65mm voice coils in 36 litre sealed box (-3 dB@26 Hz)
HxWxD/18.5” x 26.8” x 7.1”/470 x 680 x 180 mm
external = 2 cubic feet/= 57 liters
: ~18 L each driver
Procella P15:
Dual long-throw 15” drivers with Neodymium magnets and 75mm voice coils in 75 litre sealed box (-3 dB@22 Hz)
HxWxD/22.4” x 36.6” x 8.7”/570 x 930 x 220 mm
external = 4.12 cubic feet/= 117 liters
: ~37.5 L each driver
Old 19th March 2013, 05:26 AM   #3
Inductor's Avatar
1. SB Acoustics SW26DAC76-4 SubWoofer 10''
SB Acoustics :: 10" SW26DAC76-4
2. Tang Band WQ-1858 12" Aluminum Subwoofer
http://www.axiomedia.it/TB-Speakers/PDF/WQ-1858.pdf
Strassacker: Speaker Building, Components
Old 19th March 2013, 09:26 AM   #4
ReTrO's Avatar
Fantastic, I'll have a proper look through when I get home from work tonight.
Richard Wilson
Old 20th March 2013, 06:48 AM   #5
Inductor's Avatar
Question SB Acoustics SW26DAC76-4 vs. Scanspeak 23W/4557T00
A similar design but smaller in diameter is
3. Scanspeak 23W/4557T00 SubWoofer 10"
23W/4557T00 - Scan-Speak 10 inch woofer long throw aluminium cone - Europe Audio
Scanspeak 23W/4557T00 SubWoofer - Revelator
Both have (SB Acoustics SW26DAC76-4 and SS 23W/4557T00) QTC = 0.707@Vb = 39.5 L.
The smaller heavier Scanspeak has [Sd]232 cm² vs. [Sd]312 cm² for the SB Acoustics. Max. level (dB) it's lower for the Scanspeak but it goes lower also (F3). Excursion maximized for the Scanspeak with Xmax ±13 mm (Mech. ±20 mm) and for the SB Acoustics is Xmax ±12 mm.
For the 12" Tang Band WQ-1858 QTC = 0.707 is reached with enclosure volume Vb = 86.5 L (1xdriver).
You can make a super sub with the passive of the SS and F3< ±20Hz for 55 L volume (Max.SPL 1.00 m/105.6 dB).
Scan-Speak 23W/0-00-00 'Revelator'
Scan-Speak 23W/0-00-00 'Revelator' pdf
Old 20th March 2013, 07:39 AM   #6
Inductor's Avatar
INFO: SS Subwoofer with black alu cone ref. Scan-Speak 23W/4557T02
Old 21st March 2013, 08:23 AM   #7
ReTrO's Avatar
Thanks again. I'll look at these properly tonight.
Richard Wilson
Old 5th August 2014, 06:50 PM   #8
ReTrO's Avatar
I've moved house and am looking at the subwoofers again. I have spent some time at work recently using Triad speakers and quite like the look of the Bronze SlimSub in its many forms. 4" deep using a version of the SB SW26DAC76 driver should work very well in my living room for being tidy too.
I'm thinking effectively 4 of the OnWall model (albeit with square corners for easier manufacture and without the metal back plate) driven by a good QSC power amp in my AV rack. 2 on the front wall and 2 on the back. Should be a good cinema.
Richard Wilson
Old 7th August 2014, 10:43 PM   #9
ReTrO's Avatar
For power amplification how about an IMG STA-800D? Nice 1U size.
http://www.monacor.co.uk/products/pr...er/vnr/255200/
Sent from my Nexus 4 using Tapatalk
Richard Wilson
Old 8th August 2014, 02:28 AM   #10
Inductor's Avatar
Project needs to be reevaluated if using a to small of a sealed for a LT/DSP.
What's the volume (net)?
Procella P10/P15 Clones?Hide this!Advertise here!
FS: SoundSplinter Rl-p15 2 ohm DVC Subwoofer omarmipi Swap Meet 1 6th December 2010 07:42 PM
Acurus P10 in need of help boy412 Analogue Source 15 6th July 2010 05:01 PM
2 Jensen P15-RJ vintage 15" speakers GordonW Swap Meet 2 2nd August 2007 02:17 PM
AV15 or RL-p15 or Tumult 15 Jose_L Subwoofers 19 31st March 2006 04:46 PM
AKG P8, P10, P15 cartridge specs PTSOUNDLAB Analogue Source 3 19th February 2006 05:31 PM
Copyright ©1999-2017 diyAudio
