Sealed vs Ported sub?? - Page 2 - diyAudio
Old 17th March 2013, 05:47 PM   #11
Have you read about Linkwitz transform?
That will tell you a lot about getting back some bass from a sealed box speaker.
But it comes at a price: Very high power at the bass frequencies. So much so, that maximum SPL is severely compromised if you ask the transform for too much downwards extension of the bass.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th March 2013, 06:08 PM   #12
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
MDF by all accounts seems to be the default material to use for enclosures, Plywood is a different animal...One must choose a "void free" type of plywood...which is an 'un-common type....and consistency seems to be highly variable. Internal bracing can be a multitude of types....the idea of build it stronger than you think it needs, seems to be in order here. Stuffing the inside has two benefits....Reducing the size of the sealed enclosure appx 15% via Isothermal Process.....Damping of internal reflections...so that waves inside the enclosure do not rebound off the walls to "re-energize" the cone.
Myself, I use MDF for its' workability....& I won't use anything less than one inch thickness, no matter the size. This makes for a very stout structure...albeit very heavy inert structure...but I will "suffer" that choice. I use two inch screws(For 1" thickness), pilot hole, spaced every five inches, simple butt corners(One inch is great for simple butt) appropriate wood glue & screw it all down...very stout!!
__________________________________________________ Rick........
Old 17th March 2013, 06:18 PM   #13
Originally Posted by Kingnoob View Post
Stereo Integrity site suggests a 3 cubic foot sealed box
Any Tips on bracing? or building box.
I take it Dampening material inside makes the box sound louder?
If MDF better than plywood for sealed box?
Braces can be made of the same material the rest of the cabinet is made from, around 3" strips connecting opposing sides stiffen walls.
Dampening material can make a sealed box acoustically appear larger.
In a ported box dampening can reduce resonances, but will also reduce output level.
MDF is not as rigid as good plywood, and does not hold screws as well, and absorbs moisture more readily.
It is easier to get a nice looking finish than plywood, but does not hold up well on the road.
Old 17th March 2013, 08:10 PM   #14
3/4" plywood is rather durable right?
Void free is the best correct
Old 17th March 2013, 09:30 PM   #15
Inductor's Avatar
Plywood, void free/high quality is the best inside/outside where there's humidity.
Another thread on the same driver by OP here,
SI sub?? help
Old 17th March 2013, 09:48 PM   #16
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
closed apperiodic design
especially leightweight, and portable
though light, still very stiff and 'dead', due to bracing
and stuffed, the bracing also works as acoustic valve, for the apperiodic system
Old 21st March 2013, 06:28 AM   #17
DO I need to use a box building program??to create a blue print or what
I'm not sure how to cut speaker holes... but Is it hard?
Old 21st March 2013, 09:51 AM   #18
Jay is offline Jay  Indonesia
Of course. You need to use a program to calculate box volume, driver location on baffle, port diameter and length, and in some cases throat cross section, mouth cross section, length of pipe, etc.
If you don't know, it means you don't have the tools, it means difficult (I prefer to pay third party to build mine)
Old 21st March 2013, 01:52 PM   #19
Inductor's Avatar
Kingnoob,
You seem really interested. As Jay said you can use the services of a professional carpenter. People that do it themselves use a jigsaw, a router or a CNC but you don't have to learn if don't feel to.
By the way what is your flag/country. Do you use metric or imperial units where you live.
CNC Routing
Old 30th March 2013, 03:28 AM   #20
Originally Posted by Inductor View Post
Kingnoob,
CNC Routing
me & a freind built box but I have to seal up up with extra wood bracing , plus it needs more bracing so back of box doesn't flex.
I went sealed but box is large enough to make it ported if I disliked sealed.
approx 4.5-4.8 cu footer
Awaiting box'es need for extra bracing it is ported because back is open down-facing, sitting on the Styrofoam that came with the sub when shipping...Port doubles output almost.. but It seems like bass is not very controllable
sealed or ported mlr Subwoofers 20 25th March 2012 04:18 AM
SEALED OR PORTED?! carshateme Car Audio 6 11th October 2011 05:28 PM
sealed vs. ported sonu Multi-Way 25 9th May 2005 12:50 PM
Sealed or ported? mazeroth Subwoofers 13 23rd November 2004 12:44 PM
¿Sealed or Ported? eXn Car Audio 28 11th October 2004 11:05 PM
Copyright ©1999-2017 diyAudio
