Cabinet suggestions for two Eminence LAB12 - Page 4 - diyAudio
Old 23rd March 2013, 06:41 PM   #31
Originally Posted by Rullknufs View Post
I'm also missing one of the sealing gaskets for the drivers. I have sent a message to the guy I bought them from. I guess he forgot to send me both.
Adhesive backed weatherstrip foam can be used for the gasket (which the seller probably won't have and would take a month to get if he did).
Old 23rd March 2013, 06:49 PM   #32
Rullknufs's Avatar
Send a message via Skype™ to Rullknufs
I found some self adhesive neoprene. Would that work? 10mm wide and 6mm thick.
My audio and DIY blog: http://phimusic.blogspot.se/
Old 23rd March 2013, 07:04 PM   #33
That is thicker than necessary, make sure you use even torque on all the fasteners, and set them a bit at a time, making several passes on each of the 8 as you increase torque a little each time around the circle.
Old 23rd March 2013, 07:13 PM   #34
chris661's Avatar
^ +1
What sort of screws are you using to hold them?
Old 23rd March 2013, 11:47 PM   #35
Rullknufs's Avatar
Alright, I'll try to find something thinner tomorrow.
Originally Posted by chris661 View Post
^ +1
Haven't gotten to that yet. What would you recommend?
Old 24th March 2013, 05:23 PM   #36
1/4" or 4mm machine screws going in to T nuts are a good choice.
Old 24th March 2013, 06:19 PM   #37
Rullknufs's Avatar
Is M4 the largest that fits in the screw holes? I have access to M5 too, maybe that's better?
Old 24th March 2013, 07:51 PM   #38
tb46 is offline tb46  United States
The spec sheet says: Mounting Holes Diameter 0.26", 6.6mm.
Oliver
Old 24th March 2013, 08:16 PM   #39
Rullknufs's Avatar
I'll go for M6 bolts and t-nuts then. Should be best, I suppose?
Old 24th March 2013, 08:20 PM   #40
I think weltersys just mistyped w/ 4mm, 1/4"=6.35mm. M6 should be fine.
Oliver
Eminence Lab12 smallangryboy Subwoofers 25 4th January 2015 04:29 PM
Eminence Lab12, ported box sangram Subwoofers 34 13th May 2012 08:56 PM
Eminence LAB12 cheaper alternative feket663 Subwoofers 13 30th January 2012 07:34 PM
FS- eminence LAB12 and S2010 Pyroibw Swap Meet 0 12th August 2010 09:56 PM
Eminence LAB12/any take on this one? peterpan Multi-Way 4 18th April 2004 06:57 PM
Copyright 1999-2017 diyAudio
