Cabinet suggestions for two Eminence LAB12 - Page 3 - diyAudio
Old 18th March 2013, 01:12 PM   #21
chris661's Avatar
The cabinets will both be so small that standing waves etc are basically a non-issue.
30L will require more power to hit a given SPL, but both will ultimately be limited by the excursion capability of the driver.
The 30L will probably require a little eq to get sounding nice, but the lower Q of the 70L should give better results from the off.
IMO, you're going to need some eq to tame the 50Hz peak, so if you're playing with eq anyway, seems sensible to go for the smaller cabinet.
I'd advise Googling about the iNuke fans.
If it were mine, I'd add a couple of ohms in series so they run slower, and put a bypass switch across the resistor to bring the fans up to speed when the party starts
Chris
Old 20th March 2013, 07:22 PM   #22
Rullknufs's Avatar
Send a message via Skype™ to Rullknufs
Don't underestimate old people, especially not when they're your parents.
Dad came up with the brilliant idea to use my current subwoofer cabinets for the LAB12. They're about 40-45l internal volume, built of 22mm particle board. Right now they host 10" woofers but the plan is to remove them, drill a new hole for the 12" on the sides (the LAB12 wont fit on the original baffles) and then cut a new piece of particle board to put over the old baffle. And when I have two big holes in the box I'll take the opportunity to add some bracing as well (I guess it's needed?).
The shipping proved to be a bit slower than expected. The subs left Gothenburg this morning so that means another ~850km to travel before I get them.
My audio and DIY blog: http://phimusic.blogspot.se/
Old 22nd March 2013, 05:26 PM   #23
Rullknufs's Avatar
Got the subs today. Later than expected
They are in a nice condition. Tested hooking them up free-air without XO and it seemed promising. I will start with the cabinets tomorrow and hopefully have it up and running tomorrow evening.
Old 22nd March 2013, 05:28 PM   #24
chris661's Avatar
Wahey, better late than never, eh?
Pictures would be welcomed.
With regards to your current cabinets - I'd consider bracing mandatory. I'd expect the walls to flex quite a lot without some bracing, losing considerable energy.
Chris
Old 22nd March 2013, 05:55 PM   #25
Rullknufs's Avatar
Here's an album Eminence LAB12 - Imgur
I'll see what I can do about bracing. I have decided to just make the old hole a bit bigger instead of cutting a new hole on the side. The LAB12 should fit on the original baffle, hopefully.
Out of these two bracing techniques, which would you recommend?
or
Old 22nd March 2013, 06:21 PM   #26
The top for guitar, the lower for speakers.
Old 22nd March 2013, 06:22 PM   #27
Rullknufs's Avatar
Alright. The lower alternative shouldn't be that difficult to do. Just need to find some material to use.
Old 23rd March 2013, 09:51 AM   #28
Rullknufs's Avatar
Do you think this will be sufficient to brace with? The glove is a standard size winter glove for size comparison.
Old 23rd March 2013, 12:15 PM   #29
Rullknufs's Avatar
I have made the drivers holes a larger to accomodate the new drivers. Took a bit longer than expected but eventually I got it right.
I also noticed that I didn't seal all corners from the inside before so I'll have to finish that as well.
I used the stick in the picture in post #28 for bracing. I cut it into pieces with 45 degree angles on both ends. I think I got to five or six pieces per cabinet.
I'm also missing one of the sealing gaskets for the drivers. I have sent a message to the guy I bought them from. I guess he forgot to send me both.
Old 23rd March 2013, 06:39 PM   #30
Rullknufs's Avatar
Just tested the drivers in the boxes. My room was more "alive" than I had thought. Stuff vibrating everywhere and the subs still had a lot more to give.
Pretty impressive though how they actually pressed themselfes out of the cabinets a little to let out air when playing loud. I mean, the drivers are heavy as iron and yet I could hear air coming out. I really need some sealing gaskets and good screws to hold these beasts in place!
I hit about 108dB in listening position when playing some bass-heavy dubstep song. Pretty good.
Eminence Lab12 smallangryboy Subwoofers 25 4th January 2015 04:29 PM
Eminence Lab12, ported box sangram Subwoofers 34 13th May 2012 08:56 PM
Eminence LAB12 cheaper alternative feket663 Subwoofers 13 30th January 2012 07:34 PM
FS- eminence LAB12 and S2010 Pyroibw Swap Meet 0 12th August 2010 09:56 PM
Eminence LAB12/any take on this one? peterpan Multi-Way 4 18th April 2004 06:57 PM
Copyright 1999-2017 diyAudio
