Underground Sub
Underground Sub
Old 15th March 2013, 12:47 PM   #11
Silent Screamer is offline Silent Screamer  Australia
bjorno that looks very interesting... imagine an 8 horn loaded DBA flush mounted in cavities behind the front and rear walls. You would just see 8 square holes in the walls and no subs.
What I do like about the idea is no pressurization of the room. Which I am sure OB speakers would greatly appreciate, especially the RAAL dipole ribbons.
Edit:
Just doing the math on a 6 meter wide room and it is reduces the horizontal room mode cut off to 172 / 3 = roughly 57Hz. Starting to loose much of the advantage of this type of design.
With 3 meter center to center screen size will be touch and go depending on the size of the outlets.
Old 15th March 2013, 01:19 PM   #12
Ile is offline Ile  Finland
Originally Posted by Silent Screamer View Post
Not sure what you mean by manifolds.... but how about this?
You should read IB FAQ I posted.
Manifold is kind of connection box for IB sub elements, usually mounted to back space side. Normally 2 or 4 element is connected to opposite sides of box...
IB subwoofer picture gallery page 1
Don't build that kind horns from your head, result would suck without good design.
Don't understand what benefits much complicated horn have over very simple IB for hometheater subwoofer. Maybe you save two driver price and can use smaller amp, but construction is so much complicated that you lose many times that to material costs and time used.
Hard to say which would sound better, because probably no one have build both to same room.
Old 15th March 2013, 01:40 PM   #13
I tried modeling the DBA bjorno suggested and it just won't work, using a modest 600mm square outlets, it only gives a 100 inch diagonal 16:9 picture, which is not enough, and I don't want to try material over the ports to make the screen bigger, so that leave me back at either IB or TH.
Thanks Ile I will investigate the IB option in greater details.
Old 15th March 2013, 02:05 PM   #14
epa is offline epa  Netherlands
bookmarked
maybe 4 tcsound 18"tqwtp with the mouth positions as in bjorno's link.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 15th March 2013, 11:18 PM   #15
I'm not sure you would get the same effect if you deviate from the 1/4 - 3/4 placement, but there is no reason I couldn't still use the idea even if its not perfect for more even bass distribution.
Just working with the IB idea for a moment I could use the master bedroom directly above the home theatre room to provide a chamber for the IB.
Perhaps with it vented it would result in non pressurization of the room as it would be a back and forth motion with a large air buffer in between.
Old 15th March 2013, 11:53 PM   #16
3GGG is offline 3GGG  Australia
I am going to build LeCleach bass horns, to go with a 4 way horn build. After hearing the effortless dynamics and detail fr horns I just have to try a 20hz concrete bass horn. I will detail the build and feel free to jump on a cheap flight for a listen when complete.
Old 16th March 2013, 12:39 AM   #17
Sounds interesting 3GGG.
The boss expressed her displeasure with me using the master bedroom to vent the home theatre room, on the account of she says it should be separate for privacy reasons...
With just the two of us in the house I don't see who we are going to upset
I asked if it was ok to build it into the 3 x 6 meter walk in wardrobe, and that was far more acceptable, as it would be separate from the bedroom.
I could use the whole room, but there's no point in rocking the boat unnecessarily when it is still just an idea...
Old 16th March 2013, 01:38 AM   #18
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Let me see if I can find the old link to Tom P's multiple subs.
And the magazine writer who had floor to ceiling columns in his basement with multiple drivers.
Kevin
Old 16th March 2013, 02:28 AM   #19
VolvoHeretic is offline VolvoHeretic  United States
If you build a speaker under the basement floor, what happens when your sewer backs up and your sump pump motor is burnt out?
Old 16th March 2013, 02:49 AM   #20
OllBoll is offline OllBoll  Sweden
If you're going to build such an extreme build then you might consider to use twice as many drivers and slot mount them where one is reversed. This would reduce driver significantly distortion and cancel mechanical forces. Your house will thank you when playing lots of LFE content
There is a thread about this, also some information on Linkwitzlab since he uses the technique himself a lot.
If you go this route you could compensate by using smaller less fancy drivers since the strain on each driver is reduced.
Underground SubHide this!Advertise here!
Unheard, Underestimated, Underground Music zayne742 Music 18 16th February 2008 05:20 PM
There is water flowing underground.... ptwining Multi-Way 10 8th August 2006 03:49 PM
