BEST 18" Sub for a folded horn enclosure! - Page 2 - diyAudio
Old 13th March 2013, 08:37 AM   #11
ClackS02's Avatar
Originally Posted by OscarS View Post
If this is true, how are you going to design the folded horn?
I guess knowledge was a poor term to use! Designing and tuning will not be a problem, just being in the car ICE industry ive not come accross folded horns ect, Its all been about quality and SPL rather than how far you can throw the sound!.
I need a set of subs that will throw lots of bass at the audience in a large/outside environment! HELP
-Steve C
-DubRoach Production
Old 13th March 2013, 05:59 PM   #12
The more SPL generated, the louder it is at distance.
SPL falls off at 6 dB per doubling of distance outdoors.
130 dB (about what one Keystone sub with 1500 watts can do at 35 Hz) at one meter will be 106 dB at 16 meters.
Josh Ricci's Gjallerhorn can do that at 25 Hz, but is over twice the size and uses an even more expensive driver.
Doubling drivers and cabinets driven at the same power level gets you another 6 dB.
If you want SPL of 130 dB at 16 meters, you need about 16 Keystones or 8 Gjallerhorns.
That said, a large array increases forward directivity quite a bit, you would still hear that array at around 94 dB at 2048 meters (1.26 miles) away in front of the stack.
Party on, dudes!
Art
Old 13th March 2013, 06:18 PM   #13
OscarS is offline OscarS  United States
Well I suggest start modeling drivers with HornResponse as a start. With ambiguities like those I've underlined, it's gonna be tough to please such a customer-----frankly you need to be a bit more "scientific" with your terminology around here, as this isn't your run-of-the-mill car audio forum with n00bs that don't know squat. When I read something like "lots of bass", it reminds me of a 16 yr old high-school drop-out who now wants to learn how to design bad-a** sound systems with no knowledge of acoustic principles----I'm not saying this is you, I'm just saying what it reminds me of.
I can only assume you already have downloaded HornResponse have models you need critique on......
Old 13th March 2013, 08:26 PM   #14
Rojoh is offline Rojoh  Norway
Rojoh's Avatar
Why not build something tried and tested. Labsub from Live Sound: LSP Documentation Page - drawings, photos, specs and more - Pro Sound Web maybe? Not 18", but...
Putting out fire with gasoline.
Old 13th March 2013, 08:34 PM   #15
Labhorn chokes below 35 hz so it's likely not tuned nearly low enough for the type of music it's needed for in this case. Also, Labhorn has a huge hole in response right above tuning and the drivers used can't thermally handle much power by today's standards. There are better designs.
Old 13th March 2013, 09:35 PM   #16
JLH is offline JLH  United States
JLH's Avatar
My question is why did the OP choose an 18" woofer? All things being equal, 18" woofers cannot handle as high compression ratios. There is also the increased rear chamber volume required because of higher Vas. This makes the overall size bigger than using multiple smaller woofers.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 14th March 2013, 12:24 AM   #17
I can only speak for myself but I'M choosing an 18 for my next design because it's far cheaper than a couple of 12's (all else equal). I don't need a high compression ratio, and wouldn't design with one anyway since it leads to high velocity and possible turbulence and distortion in the narrowest section of the horn. I'm choosing a driver that has the Vas and qts required for my design and desired size. Larger drivers will usually have higher xmax than smaller drivers.
Besides, weltersys (member here) has extensive experience with some of the newer, larger drivers, and he has some driver recommendations with very strong cones and a well known horn design to back up his claims. I can't afford to experiment so I have to trust people like him and hope everything works out ok.
Old 14th March 2013, 01:34 AM   #18
nigelwright7557's Avatar
Try Blue Aran - Professional Sound and Lighting
I have had some good deals with them.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 14th March 2013, 09:21 AM   #19
epa is offline epa  Netherlands
you cannot just drop any driver in to a horn,even if the driver is a good horn driver.
you design the horn "around"a driver.
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 14th March 2013, 03:03 PM   #20
ClackS02's Avatar
HA! Thats not me! i want something with headroom! Id rather have a set of subs at half volume than at full with the same SPL !
This is it! I need to speak to someone that has first hand knowledge ! Its all well looking at graphs, but id like to know that what im building is going to impress!
-Steve C
Need help replacing drivers in Dual 18" Folded Horn Sub james122004 Subwoofers 9 20th September 2012 02:02 PM
18" horn enclosure simpleacoustic Subwoofers 15 21st September 2011 08:31 PM
18" Folded Horn Enclosure the_kelso Subwoofers 12 12th February 2006 07:53 AM
Can I multiply an 18" folded horn cab by 0.8 for a 15"? Optical Subwoofers 7 31st October 2004 04:37 AM
18" Folded Bass Horn Design djdan Multi-Way 11 27th October 2003 09:21 AM
Copyright 1999-2017 diyAudio
