Subwoofer cabinet advice
Old 29th March 2013, 03:47 AM   #41
jazzcyclist is offline jazzcyclist  United States
Originally Posted by Inductor View Post
Yes, look below.
(2.1ft³ = 59.465L for 2x drivers)
Your mistake if using a two driver system instead of one driver for the same internal volume is that you need a driver for smaller enclosure volume. This, if not using equalization like in the case you are comparing to (sub Dayton Audio RS1202K). Does it make any sense to you?! Summarizing, without EQ you need eventually a bigger box (it's this case) or another driver for a smaller box, there are drivers for 30/40 L enclosures with a better Qtc closer to 0.707.
http://www.daytonaudio.com/media/res...ser-manual.pdf
I'm not quite sure what you're saying, but if you're saying that the Dayton Audio RS1202K is able to get away with such a small enclosure because of the equalization of the SPA1000 plate amp, I concur. Generally speaking, it's pretty obvious that sealed subwoofers need more low-end equalization than ported subwoofers.
Old 29th March 2013, 12:58 PM   #42
Inductor is offline Inductor  Portugal
Inductor's Avatar
"Generally speaking, it's pretty obvious that sealed subwoofers need more low-end equalization than ported subwoofers."
Did you read that or it's your assumption?!
Old 29th March 2013, 01:56 PM   #43
It's my assumption since sealed designs start rolling off at higher frequencies that ported designs.
Old 30th March 2013, 04:10 AM   #44
Inductor's Avatar
Is not obvious.
In this case is not because of that, but because you are using a sealed enclosure smaller than ideal with a high Qtc. The same for ported.
What is obvious is that almost all the times the sealed systems don't need correction when using the correct driver in a convenient enclosure. The room gain does it's job. EQ it's a gimmick for the s-t-u-p-i-d HT subs.
(uploaded demo pics from sealed enclosures by Petoin Dominique)
Old 30th March 2013, 10:41 AM   #45
Is not obvious.
My experimentation with WinISD contradicts what you're saying. In every case, the sealed designs start dropping off earlier than the ported designs. Perhaps you can point me to an example of a subwoofer that does the opposite. Also, it's obvious that not everyone worships at the alter of 0.707 Qtc as you do as eveidenced by the 1.00 Q of the Dayton Audio RS1202K.
Old 30th March 2013, 09:55 PM   #46
Inductor's Avatar
You are entitled to your own opinions. There are drivers made for each of the systems.
Old 1st April 2013, 02:05 PM   #47
I didn't know WinISD gave opinions. My bottom line question is why Dayton Audio's best subwoofer kit consists of two of these subwoofers in a 2.1 cubic-foot cabinet? If you or anyone else here can provide an objective well-reasoned answer, I would appreciate it.
Old 1st April 2013, 05:23 PM   #48
turbodawg is offline turbodawg
Originally Posted by jazzcyclist View Post
..........why Dayton Audio's best subwoofer kit consists of two of these subwoofers in a 2.1 cubic-foot cabinet?
No idea. It's a rather poor design IMHO. Cabinet is too small, it's sealed, and it's MDF.
Old 2nd April 2013, 02:35 AM   #49
Inductor's Avatar
Never heard (of) a sub better than my stereo. Much less for Jazz. I guess that's how good they are... or they are just something to spend your money on?! Confused? When you have a small house/room you need a small sub, or think you need. If you dig it, awesome. If you don't, awesome.
Subwoofer cabinet adviceHide this!Advertise here!
Odd subwoofer cabinet question... semi open baffle.. a kitchen cabinet peace brainerd Subwoofers 8 30th November 2012 06:15 PM
Cabinet dimension advice awol66 Full Range 12 29th July 2011 03:31 AM
need advice regarding painting the cabinet eitanwaks Multi-Way 2 23rd November 2009 09:11 PM
Need advice on cabinet finishing (lacquer) alphaGeek Multi-Way 23 25th March 2003 05:24 PM
Copyright ©1999-2017 diyAudio
