Subwoofer cabinet advice
Old 28th March 2013, 02:19 PM   #21
jazzcyclist is offline jazzcyclist  United States
I just ordered two Dayton Audio RSS315HFA-8 subwoofers and a Crown XLS 2000 amplifier. I'll post pictures of the completed project when I'm done.
Old 28th March 2013, 02:29 PM   #22
turbodawg is offline turbodawg
Dayton Audio RSS315HF-4 12" Reference HF Subwoofer 4 Ohm High Fidelity Reference Series 295-464
Ported.
Old 28th March 2013, 02:31 PM   #23
Originally Posted by jazzcyclist View Post
After much deliberation, I've pretty much decided on using two DAYTON AUDIO RSS315HFA-8 subwoofers in a sealed design based on the advice of one of the folks at Parts Express.
You may run into oil-canning issues with the HF in an enclosure of that size.
http://www.google.com/#hl=en&output=...48&safe=images
Sealed is over-rated.
Old 28th March 2013, 04:21 PM   #24
Are you suggesting that this enclosure is too small despite the fact that it's twice the size of the enclosure provided with the Dayton Audio RS1202K subwoofer kit?
Why do you think so many of the high-end subwoofer manufacturers use sealed designs? Why do you think the technical folks at Parts Express are advocating a sealed design for a product that I'm buying from them anyway?
Old 28th March 2013, 05:43 PM   #25
Inductor is offline Inductor  Portugal
Inductor's Avatar
jazzcyclist,
Most of diy'ers members don't follow instructions (like you).
We are here just for fun.
(ps. I don't care who says what in PE. Go to their forum if you like it best.)
Old 28th March 2013, 07:53 PM   #26
Upon further reading, it seems their noise issues were addressed:
OCI: Oil Canning Investigation
Regardless, the box is still on the small side for those and sealed provides no improvement in sound quality vs. a properly designed ported box which will have better extension.
Old 28th March 2013, 08:30 PM   #27
I know WinISD calculates an internal volume of 194 liter for a sealed design using these subwoofers, but it's my understanding that you have a lot more latitude with the cabinet size when you're building a sealed enclosure, as opposed to a ported one, which is a lot less forgiving when you deviate too much from the ideal size.
Old 28th March 2013, 08:43 PM   #28
Yes, you'll just get less extension. Which is fine if you have a small room and/or a PEQ and no need for any serious output. My pair of 15" ref HO's run out of steam pretty quickly when run sealed/eq'd.
Old 28th March 2013, 09:13 PM   #29
Inductor's Avatar
I have a subwoofer cabinet that I've had for years which I never used due to a change in plans. The cabinet is very sturdily constructed (1.5-inch walls and 2-inch baffle) and has an internal volume of 4.27 cubic feet (121 liters)
Hey, your cabinet works better with one woofer than with two, see post #18 option a for 2 woofers (60or ~56 about the same) for very high Qtc. That's no good, that's just my point to you... oink oink oink or bell curve without EQ.
Good luck.
Old 28th March 2013, 09:18 PM   #30
Inductor's Avatar
The same (above post) with sealed or bass reflex anyway...
Subwoofer cabinet adviceHide this!Advertise here!
Odd subwoofer cabinet question... semi open baffle.. a kitchen cabinet peace brainerd Subwoofers 8 30th November 2012 07:15 PM
Cabinet dimension advice awol66 Full Range 12 29th July 2011 04:31 AM
need advice regarding painting the cabinet eitanwaks Multi-Way 2 23rd November 2009 10:11 PM
Need advice on cabinet finishing (lacquer) alphaGeek Multi-Way 23 25th March 2003 06:24 PM
