Subwoofer Design Questions
Old 28th February 2013, 04:47 PM   #1
sdp07d is offline sdp07d
Default Subwoofer Design Questions
I'm looking to build a subwoofer to go with my TM overnight sensations. I am primarily concerned about how my music sounds but will be using it for home theater as well. My budget is around $300 for all parts. I would prefer the sub be as small as possible.
I have modeled a few drivers but I'm beginning to realize that I'm not sure what response curve would be ideal for music (I've read flat).
I have modeled a Dayton Audio RSS265HF-4 in a 55 liter ported enclosure and tuned it to 23 Hz using a 4 inch pvc pipe. I've attached the response curve, extension and port velocity.
Is this curve an acceptable looking curve?
Would a Dayton Audio SPA250 250 Watt Subwoofer Plate Amplifier be an acceptable amp?
Is the port velocity acceptable?
Old 28th February 2013, 05:15 PM   #2
weltersys is offline weltersys  United States
weltersys's Avatar
Flat response is a good thing to shoot for, though room position, size, openings will change the response considerably.
The port velocity looks good, with a 3/4" roundover there should be no chuffing (port noise) unless driven hard below Fb.
Although the amp is capable of driving the speaker to Xmax, I'd probably want to get something with more headroom, like in the 400-500 watt range.
Although I have no experience with how the SPA250 sounds when clipped, clipping most amps sounds far worse than a bit of speaker flapping.
That said, if you think 106 dB at one meter is enough level, no need to get more power.
Old 2nd March 2013, 11:27 PM   #3
head_unit is offline head_unit  United States
Kudos to Dayton/Parts Express, but actually I found Guitar Center had insane $/watt on pro amps (unless you want to integrate a plate for space or aesthetic reasons).
A subwoofer should really NOT be "as small as possible." Trying to achieve that runs into a litany of sins:
- Small diameter drivers
- Small box meaning the bass doesn't go low OR super low efficiency
- Porting becomes stupid, because a big enough port becomes bigger than the box (and with small drivers you need a port to get enough output to even hear the lows).
Can these be overcome? Yes, to a degree. It's called "engineering challenges" ha ha.
But each extra cubic foot you allow yourself will yield a lot more design freedom and better results.
As for the response, I prefer a kind of drooping, more extended bass. This to me equates to a tighter sound, and matches room gain better. You could lengthen the port a bit (if you have room) &/or stuff the cabinets (which you should anyway).
Subwoofer Design QuestionsHide this!Advertise here!
Metronome style design for multiple drivers, a number of design questions mountainhick Multi-Way 5 28th January 2010 03:31 AM
Various Subwoofer Questions - Thanks topher_m Subwoofers 1 1st March 2008 04:44 PM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 10:31 AM
subwoofer enclosure design questions halbritt Subwoofers 3 23rd March 2004 02:18 PM
Subwoofer design questions Theli Subwoofers 18 15th January 2004 04:38 AM
Copyright ©1999-2017 diyAudio
