#11 | |
![]() Mission 73pi - passive sub | AVForums.com - UK Online Last edited by Inductor; 5th March 2013 at 02:47 PM. |
#12 | |
#13 | |
If you don't want to make homemade, Google "Harrison FMOD" or look at Amazon or Parts Express. |
#14 | |
But, I already went the "easy route", and maybe what would have been the most logical. Took the good 'ol 1998 8" 50W Audio Source SA-50 that I had in the family room (very good with music and movies, but lacked the extra "oomph" to rattle windows and feel explosions in your bones), and moved to my home office, as it was compact enough to fit under a PC workstation. It's plate amp already has the "by-pass" needed for satellite speakers. Then I ordered a Bravox PXW12D-2, and Dayton SPA-250 Plate Amp to build a sub for the family room. With a 200L enclosure it will produce an Fb of 22 Hz, and an F3 of 20 Hz, and an all concrete home like mine can make it go even lower. Last edited by guangui; 7th March 2013 at 05:45 PM. |
#15 |
You got two Basic Active Subs then...
#16 |
#17 |
The main problem with the passive is that, besides what was already said, you have to match sensitivities very wisely, in this case for production models they came as a complement of the satellites already tested by the manufacturer.
| Basic SSE input RCA jack wiring question | Horsebox | Tubelab | 6 | 24th April 2012 02:55 PM |
| First build: Basic wiring question | soren5 | Class D | 8 | 19th October 2011 06:27 PM |
| Super, basic power supply wiring question | madmonda | Power Supplies | 1 | 8th April 2011 08:44 AM |
| Basic wiring problem | Bobhof | Parts | 2 | 22nd April 2006 02:51 PM |
| basic wiring for t-amps HELP! | miles488 | Chip Amps | 3 | 6th February 2006 08:41 PM |
