Subwoofer Suggestions / Help
Old 20th February 2013, 09:06 PM   #1
PPCFlyer is offline PPCFlyer  United States
Default Subwoofer Suggestions / Help
I am putting together a home theater in the only room I have available, my living room. It is 19X19 with 10ft ceilings. To complicate matters it has a 5X7 opening to the kitchen / dining area, a 5X7 opening to the foyer, and a louvered door leading to the hallway.
My goal is to have a powerful low end for movies and may be used 10-15% of the time for music. My receiver is an Onkyo 805, and my LCR setup are some discontinued Klipsch SLX wall mounted speakers. (I would like to eventually replace these) and for rear surround I will be installing some ceiling speakers to keep the wife happy.
I have an entire corner I can use for the sub, and was thinking about a sonotube model. My brief experiments with sonosub an winisd were using a 15" Dayton Titanic III in a 10 ft3 18" sonotube tuned to 18Hz. Total hight was around 7' tall. However, I am open to any suggestions. I would like to keep the driver cost under $400 or so. For an amp I had planned to use an EP2000.
Thank you for any assistance you can provide.
Kendall
Old 20th February 2013, 09:17 PM   #2
Aucosticraft is offline Aucosticraft  India
you can enjoy Good bass with proper placement of subwoofer. can you post the layout of your living room?
There is always a first time....
Old 21st February 2013, 02:22 AM   #3
Green is the TV, Orange is the couch, Brown is a louvered door usually closed.
Old 21st February 2013, 05:35 AM   #4
Well, I had tried some positions ,while installing my home theater, and at my friends place too. while recommending the position to my friends I see their choice. the same I am sharing here with you.
A - Good for lot of bass, bit messed, not much tight.
B - lot off bass, but somehow I didn't feel it syncs well with the other speakers.
c- This is the best position according to me, good , clean bass. goes perfect for movies as well for music. Just keep distance of 4 inches from the wall behind it.
add a long cables for the test. move sub-woofer around. play different music and movies, and then decide what suits your taste.
Old 21st February 2013, 12:29 PM   #5
Thank you for the input on the location. I had planned on "A", but "C" is certainly where I will try it also.
Now, can you recommend and driver and enclosure that will work well for my goals?
Old 21st February 2013, 05:59 PM   #6
Inductor is offline Inductor  Portugal
Inductor's Avatar
Kendall, I read your comment about the sonotubes...
Bilder pň SVS PB12-Plus
Minhembio.com - Hemma hos MrLelle - Sonosub -Typ SVS 12 Plus DSP
Old 22nd February 2013, 12:50 AM   #7
Can you recommend and driver and enclosure that will work well for my goals?
Bueller? Bueller?
Subwoofer Suggestions / HelpHide this!Advertise here!
Subwoofer suggestions argonrepublic Subwoofers 2 28th September 2011 05:15 PM
Suggestions for subwoofer JimmyJimJimJimy Subwoofers 8 26th July 2006 06:09 PM
In need of a dynamic subwoofer, need suggestions tf1216 Subwoofers 20 2nd May 2006 06:18 AM
Subwoofer amp suggestions soundNERD Chip Amps 1 27th September 2003 12:42 PM
Any suggestions for a subwoofer that can go up to 200Hz? malisz Subwoofers 10 4th May 2003 03:39 PM
