21 Inch Enclosure - diyAudio
Old 13th February 2013, 05:49 AM   #1
abcdmku is offline abcdmku  United States
Default 21 Inch Enclosure
Well. I wanted to try the 21" speaker MCM has. I don't know what to expect but the speaker should be in Thursday, or Friday. I will test it out this weekend. It’s a cheap speaker so I figured I'd give it a go. I've had 3 18"s from MCM and had no problem. I tested one 18" MCM next to a B&C 18", both in an enclosure at the size required by the speaker, and I tuned them both to ~50Hz. The MCM and the B&C both performed very well. I used a iNuke3000DSP to power them. The B&C started to smell after a blast of some sine waves even though the iNuke only puts out 450W at 8 Ohm. The B&C takes 600w RMS and 1200w max. The MCM on the other hand has a 300w RMS rating with a 600w peak. I never started to burn anything giving the MCM speakers the same power as the B&C. The MCM has been powered with the iNuke for almost a year and it still works fine I always gave it max power the amp would let me. (not bridged that is) Anyways the only audible difference is when you got to higher frequencies; the B&C produced crisper highs. Well, it’s a SUBwoofer, I don’t need it to play anything above 250 tops. Now I know there are times where you want the higher fidelity, like a theater, or a home theater. (The reason I used a B&C) But let’s be honest. If you have an EDM concert with 1000’s of screaming ragers, they won’t hear a difference in quality between a 21” that cost $800 or $100.
Anyways, getting back on topic, The design I modeled will give a response from 35-280hz at 97Hz +/- 3dB, and 130 dB max. The box is 36x24x24 with an internal volume of ~9 ft^3, with two 2"x22.5" ports.
If anyone can think of a better design feel free to post it!
My requirements:
-Low end to be about 35Hz (the lower the better)
-High end at least 120Hz
-Longest length has to be under 37"
-1w/1m SPL of 97dB+ (in a half space(
-Uses no more than one 4x8 sheet of wood, and one 49"x22"
If your design is better than mine I'll build and test that instead (my design is by no means all that great, it was just a simple enclosure with an okay response)
*Please note that the enclosure I showed modeled in post #3 has nothing to do with my 21" enclosure. I was just showing what Transmission Line could do*
Old 13th February 2013, 08:05 AM   #2
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Every driver I've bought from MCM has been far from spec with the exception of the 55-2421's.
Let us know how it turns out will you. With a tuning that high and a proper high pass filter excursion should not be a problem. What did you use to model your box? That FR graph looks nice...
Dan
Old 13th February 2013, 01:38 PM   #3
NEO Dan, I used "Leonard Audio Transmission Line". It's a new software but so much easier to model in it.
Here's an example of a design:
I was reading Thawach's post about his "Thailand sub projects". I found an interesting sub that I tried to model in Hornresp, but just couldn't get it right. Here's the speaker plan:
This is what I input:
This software is still in beta testing. That's the reason I have these pictures, to point out some things I thought should be changed. The interface is still the same, though. Something else that's nice the software has, is that you can grap you design where it displays it and move it from there. Also you can change units, and graph extents. Here's a picture of the Setting windows, and ill toss in the Amp window to:
Here's a link to the post:
Transmission Line Modelling Software
Here's a link to the software download:
Transmission Line
Old 13th February 2013, 02:30 PM   #4
tb46 is offline tb46  United States
Hi abcdmku,
This sounds interesting. Could you share the model numbers for the MCM 18" and the B&C 18", and do you have measured T/S parameters for the MCM 18"? Finally, will you be measuring the T/S for the MCM 21"?
It should not be hard to get a good simulation out of Hornresp for this speaker, try it with the Compound Hor Driver Arrangement, that way you have something to compare to the transmission line software.
Oliver
Old 13th February 2013, 04:11 PM   #5
tb46, I might measure the T/S for the MCM 21". Right now I'm just testing performance. Perhaps if one day I buy the Dayton Audio Test System, I'll measure quite a few MCM and other Drivers. For now I'll stick to Just using a Multimeter and Excel. I never got around to measuring the 18"s I already sold them, next time I buy an 18" MCM I'll be sure to measure the T/S. I still need to measure the RMS power out from the iNuke for my other thread about the new iNuke12000. (it lead to how reliable the iNukes are) I wanted to measure the iNuke last weekend, I'll probably end up measuring both the 21" and iNuke this weekend, when the 21" comes in.
For comparing Hornresp and Transmission Line, I already did some test, and the results were identical. One plus of Transmission Line, is that you can get a more accurate enclosure input.
Here are the model numbers and links to the datasheets:
B&C Speaker (18PS76):
http://www.bcspeakers.com/PDF/PRD/18PS76.pdf
MCM Speaker (55-2954):
http://www.mcmelectronics.com/conten...ts/55-2954.pdf
Oh and please note that the enclosure I showed modeled up there has nothing to do with my 21" enclosure. I was just showing what Transmission Line could do.
Old 13th February 2013, 05:52 PM   #6
weltersys's Avatar
If you have an EDM concert with 1000s of screaming ragers, they wont hear a difference in quality between a 21 that cost $800 or $100.
B&C uses the AES power ratings which have a 6 dB crest factor, sine wave testing only has a 3 dB crest factor.
Beware that if you use 600 watt sine wave (about 70 volts into 8 ohms) you are at double the power of a 600 watt AES rating.
Be careful, keep sine wave tests short.
Also beware that clipped sine waves have even less crest factor, a "450 watt" clipped amp could potentially put out a lot more than 450 watts.
As far as hearing a difference between speakers, if one has double the Xmax of another, properly powered in a properly designed box, it will be capable of 6 dB more output, a difference easily detected by almost anyone not totally wasted.
Generally you get what you pay for, high Xmax 21" need huge expensive magnets.
If cabinet size is a concern, they may be worth it.
If cost is a concern, TH can beat out BR by 6 dB or so, but require more cabinet volume.
Art
Old 13th February 2013, 06:10 PM   #7
Hi abcdmku,
Thanks for the links. That 18" (55-2954) is certainly inexpensive, now if only one had the actual T/S parameters. :-)
Oliver
Old 13th February 2013, 07:32 PM   #8
NEO Dan's Avatar
REW/ Room EQ Wizard can measure TSP's now.
Dan
Old 4th March 2014, 07:14 PM   #9
a.wayne is offline a.wayne  United States
Sin Bin
Its been a year , any news on the performance of the MCM21 ...?
Old 4th March 2014, 07:33 PM   #10
haha, I was a little shocked to see this post on the front page. I'm currently working on this. Anyways, The 21" does move a lot of air, but doesn't make all that much noise. Also can't handle as much power as the 55-2954. I abandoned this project because my dual 18"s in a smaller box preformed a lot better. Speaking of which I need to get going, I'm on my way out to pick up the wood for my new 18's. I was just making the cut sheet for it when I saw this. I will post a more detailed response later today or tomorrow.
Best 10 inch sub drivers for sealed enclosure brox Subwoofers 21 6th July 2014 07:05 AM
Enclosure for Tannoy Red 15 inch. murphythecat8 Full Range 1 8th November 2012 05:21 AM
Commercial enclosure for exodus anarchy 6.5 inch john dozier Subwoofers 5 27th June 2012 12:11 PM
Exodus 21 inch Moondog55 Subwoofers 5 16th October 2011 01:03 PM
what type of enclosure to use for 6.5 inch Bolton somakmaitra Multi-Way 7 10th February 2006 05:12 AM
Copyright 1999-2017 diyAudio
