#11 | |
Not so. At very low frequencies there is a theoretical +6 dB improvement in SPL response each time the solid radiation angle is halved. 3 dB is due to improved acoustical loading conditions (enabling twice the power to be radiated), and the other 3 dB is due to the doubled power radiating into half the space. Going from free space to eighth space therefore gives an 18 dB increase overall. At very high frequencies (assuming constant directivity) there is only a +3 dB enhancement - the acoustical loading conditions do not change when the solid radiation angle is halved. Going from free space to eighth space therefore gives a 9 dB increase overall. The attached example shows the difference going from free space (4 x Pi) to eighth space (0.5 x Pi). The low frequency response is improved by 18 dB and the upper frequency response by 9 dB, as expected. Kind regards, David
www.hornresp.net |
#12 | |
Here's an example of a tapped horn (using a 6 inch driver - tang band w6-1139) I did way back in 2009, back when we were still fumbling around trying to figure tapped horns out. Total cost was about $75 (in 2009 dollars) including driver and wood. ![]() ![]() ![]() ![]() Pic 1 shows it's not very large at all, the missing dimension (width) is 8 inches. Pic 2 shows groundplane response (outside in my driveway at about 7 meters away). Pic 3 shows same as pic 2 but with a bunch of stuffing crammed in the mouth hole. Pic 4 is the same horn in the corner of my room, measured at the listening position (no stuffing, and the null is worse due to floor/ceiling cancellation). SPL is not absolute in any of these, the mic is uncalibrated and these were taken at different distances under different conditions. If I were to do this again today it wouldn't have that nasty dip and I could easily get the full 3 octaves out of it just by moving the driver a few cm back from the mouth. For that matter, I could change it from a tapped design to front loaded and still get the same bandwidth in the same size package. As you can see, it hits 20 hz no problem in a very small package. When used below 80 hz it's the best sounding sub I own - which includes front loaded, ported, tl and sealed. That's a subjective judgement but it's true as far as I'm concerned. You could easily argue that it's not a full sized horn, but most aren't. With the fingers on one hand, I can count the number of properly designed full sized bass horns I've seen in my lifetime. A stack of 8 Labhorns being one of them. You could easily argue that tapped horns are not really horns, but then again, most front loaded horns are not horns either, by the classical definition. The vast majority are quarter wave resonators, front loaded and tapped. Just because a classically defined horn won't fit inside a dorm room doesn't mean you can't hit 20 hz easily in a small enclosure with a flare that expands from throat to mouth in a package that 1 man (or woman) can easily carry; will easily get loud enough to get you evicted, and sound great at the same time. You don't even have to use the room's corners as part of the design. Last edited by just a guy; 10th February 2013 at 06:51 AM. |
#13 |
I am unworthy of the care just a guy puts into his post. True, never heard one - and that should mean something to this forum which is the world's sole repository of posts favourable to "tapped horns."
You have shown (and I have always believed) that you can hand-configure through good design and luck excellent small frequency range speakers with a "tapped horn, BR, or Karlson. But those systems feature a tactic I find repellant as a concept: trafficking in resonances as a principal means of boosting bass. Footnote: luck (as in choosing a TH driver) not a big factor in other designs. My real problem is that I find it appalling to call these boxes horns. The part that kind of looks like a horn is just a distance spacer, no different than the volume of a BR or length in a TL; maybe the taper has some minor benefit but it does no horn transformations worth fussing about much. I believe calling it a horn (a high-status name) arose from discreditable commercial motivations rather than from anything in the patent(s). TH can be just right, I suppose, for many church halls and maybe on a good day for home systems, like BRs and Karlsons. Ben
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), mixed-bass Klipschorn w/param EQ plus giant OB using 1960's Stephens woofer HiFi aspirations since 1956 Last edited by bentoronto; 10th February 2013 at 08:40 AM. |
#14 |
[repeat post bug]
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), mixed-bass Klipschorn w/param EQ plus giant OB using 1960's Stephens woofer HiFi aspirations since 1956 |
#15 | ||||
I will work with hornresp a bit tomorrow if I get a chance. I am not so much going for a "true horn" as a sealed enclosure that is designed around the fact that it will be corner loaded, taking as much advantage of that as possible.Quote:
I'm not asking about tapped horns. If you are just here to argue against tapped horns or terminology please start your own thread.Quote:
#16 | |
"Any fool can know. The point is to understand" - Albert Einstein |
#17 |
A rather big corner horn, I think the graphs gives you most of the relevant information but use Google translate if you are less than fluent in Swedish
KensonPro Home Last edited by DrBoar; 10th February 2013 at 02:14 PM. Reason: swinglish |
#18 |
#19 |
William Cowan has a horn on his website that uses the corner as the last horn segment
Horn Subwoofer Might be worthwhile checking it out for some ideas
#20 |
Hi kctess5,
Post #1: "... standard dorm sized rectangle roughly 10'x15'..." How about carpenter's corner tapped horn Can someone help me model a horn for a driver in my basement? inlowsound.com , or how about something real: headphones? :-) Regards,
Oliver Last edited by tb46; 11th February 2013 at 02:36 PM. |
| Eckhorn 18 Corner Horn | Carl_Huff | Multi-Way | 7 | 6th October 2010 07:21 PM |
| Corner Horn | tinitus | Multi-Way | 30 | 13th December 2006 11:10 PM |
| Why could corner horn not be this simple? | mashaffer | Subwoofers | 1 | 12th March 2006 01:37 AM |
| corner horn and writing table | hm | Subwoofers | 12 | 29th December 2005 12:13 PM |
| 1/4wave corner horn scan? | mikee12345 | Multi-Way | 14 | 11th April 2003 12:46 PM |
