#21 |
To change the 'doesn't make sense' to 'makes sense in post#1': Here is a few easy calculations (cut and paste pictures') to ponder on, added here in order to clarifying the usefulness of the driver.. or not, if you disagree... b
#22 |
WinISD is fully capable of graphing cone excursion. I suggest you look around the menus on the charts. It is there.
#23 | ||
I did manage to find the cone excursion graph in it when I went back and looked more closely last night, though. Annoyingly, WinISD Pro does not work well on this machine; it crashes out with a memory access violation whenever I try to exit it. Not sure if it's the machine or the program, WinISD beta hasn't exactly been bug-free for as long as I've been playing with it (years...) either, so... I did go back and recheck *every* menu in WinISD beta as well: WinISD Beta tour - YouTube I don't see that capability anywhere. I'll have to familiarize myself with WinISD Pro. |
#24 | |
You can use task manager to shut it down. A little inconvenient, I know, but IMHO its a decent enough program to give it 2 seconds of your time to close it. |
| Linear voltage regulator: how to make good use of "sense" and "ground sense"? | NeoY2k | Analog Line Level | 7 | 6th September 2008 11:35 PM |
| About to build my enclosure...Does this 4th order bandpass box make sense? | treedog | Subwoofers | 7 | 17th January 2005 12:55 AM |
| Does this make sense ? | 00940 | Solid State | 7 | 27th March 2004 09:29 PM |
| does this make sense? | nosegoblin | Solid State | 9 | 14th February 2004 02:19 PM |
| Does this make sense? | Illusus | Chip Amps | 11 | 25th September 2003 01:59 PM |
