Driver Reccomendation for 5 cubic Foot Enclosure.  Home theater use
Old 7th February 2013, 12:17 AM   #1
permo is offline permo
Default Driver Reccomendation for 5 cubic Foot Enclosure. Home theater use
I got a little bored and started putting the cart before the horse. I chopped up a sheet of 3/4 pine plywood and built a subwoofer enclosure to fit a space in my basement. I know that the plywood is not the best. So, I then cut, screwed and glued 3/4 MDF to the outside so I now I have a 1.5 inch thick, 80 pound driverless box.
I already have my mind set on ported. I need a driver. I have 160 watts RMS via audio source amp 100 ready for this project, and a budged of $100 (willing to bend a bit). So efficiency is something to consider here, considering the low power available.
I would LOVE to get to 20 hz at F3 but I understand that this may not be possible. I have been looking at the dayton audio classic DVC 15 but not to happy with that sub in 5 Ft3.
My DIYAUDIO peeps have never let me down!
Old 7th February 2013, 04:39 AM   #2
Inductor is offline Inductor  Portugal
Inductor's Avatar
5ft│ = 141.58L
Hi permo,
All it's possible, but if you start by saying that you have a budget of $$$.00 not feasible then your beautiful project will vanish in thin air. So,
With a $170.00 driver you can get a beautiful 22.5mm Xmax and a horrendous ~60 or 65mm peak to peak and 43mm Xmech (one-way) from the data sheets.
With your project you will have F3=23 Hz in "free field" conditions and F3=18 Hz in your room with a Qtsb of 0.36. You can tune your port(s) to ~FB=18/19 Hz
Stereo integrity HT 15" Dual 2/4 Ohm subwoofer
Stereo Integrity HT 15" Subwoofer - Google Search
Thanks for waiting...
Old 7th February 2013, 12:26 PM   #3
Wow............thats an awesome driver. Would 150 watts even begin to drive that woofer?
I was also looking at this:
http://www.parts-express.com/pe/show...number=295-512
The 15 incher you reccomended seems like the winner tho.
Old 7th February 2013, 01:25 PM   #4
tb46 is offline tb46  United States
Hi permo,
The Infinity 1262W models fine in pairs, and you should be able to find them at a reasonable price (amazon, ebay...).
Oliver
Old 7th February 2013, 01:28 PM   #5
Originally Posted by tb46 View Post
Hi permo,
Thanks TB! By the way, the TQWT is still performing amazing. It seems like the lower the frequency the more it likes it!
Old 7th February 2013, 07:36 PM   #6
picked up a 1260W for $49 shipped...that just seems wrong. So cheap. I am going to plug her into winisd tonight. I am going to reduce the volume of my enclosure to 4 cubic feet with blocking and see what happens in all likely hood. With an FS of 23hz I should be able to get an F3 near 20hz if I tune below FS......wish me luck.
Old 7th February 2013, 11:15 PM   #7
norman bates is offline norman bates  United States
norman bates's Avatar
sealed for a car looks sweet
Qtc .707
VB = 1.28 Ft3
fsb = 42.60 hz
F3 = 42.61 hz
Standard ported looks fine too, I'd use 2 in that 5ft3 enclosure.
vb 2.62 ft3
f3 24.68 hz
tune 24.33 hz
thats some serious 13mm xmax.
You'd need a HUGE port to prevent chuffing at higher volumes.
Use a shelf port so it isn't as long as a standard round port (8" diameter maybe by 36.8" long for 2 driver in shared box).
Nice pick of a driver though for the cash.
Old 7th February 2013, 11:22 PM   #8
With bracing, driver displacement and port displacement I got my enclosure right at about 4 cubic feet. Here is what I came up with
4 cubic feet
Tuned to 23 hz
4 " port 13" long gives vent mach of .10. I will flare the port
F3 right at 20 hz.....
Not too shabby for a $49 dollar driver. I should have it up and running in a week. I am fairly confident it will sound pretty good.
Old 7th February 2013, 11:29 PM   #9
well.............
at what power level ?
Their own paperwork has 1 driver in 2ft3 tuned to 32hz with a 4" port, and you can see the excursion isn't lessened very much at 300 watts. A larger port will lessen the excursion, and it will sound better.
You want to use 2 drivers and tune lower with a single 4" port ?
I don't consider my dual 15" with 8mm xmax (in single box) to have enough port area (4" diameter) for a 27hz tuning................
I've used dual 18's with 4.3mm xmax in a shared box with a 12" port for a 27hz tuning.
But it's up to you.
Old 8th February 2013, 02:07 AM   #10
Originally Posted by norman bates View Post
well.............
But it's up to you.
I am using a single driver. I think the 4 inch port is adequate.
Driver Reccomendation for 5 cubic Foot Enclosure.  Home theater useHide this!Advertise here!
Best MarkAudio driver for my home theater kctess5 Full Range 13 19th June 2012 04:40 PM
Is this driver a good value candidate for simple 100W 3 to 4 cubic foot sealed sub? peace brainerd Subwoofers 25 17th September 2011 07:00 PM
Decent 18 inch woofer for a 7.5~8 cubic foot bass reflex enclosure? Upstate NY low life Subwoofers 9 9th July 2011 08:35 PM
Is OmnesAudio driver OK for home theater application? goodspeaker Subwoofers 6 25th May 2006 09:27 AM
fostex 206 in 2.5 cubic foot box JimW Full Range 6 5th January 2005 05:50 PM
