diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Subwoofers (http://www.diyaudio.com/forums/subwoofers/)
-   -   dual 15" Reflex Sub help (http://www.diyaudio.com/forums/subwoofers/229416-dual-15-reflex-sub-help.html)
maxo 5th February 2013 09:31 PM
Guys,
i was going to get a pair of these
http://www.fullcompass.com/common/fi...ty%20specs.pdf
at a pawn shop but they wanted 400 for the pair
and since the drivers seems to be in very bad condition i decided to build my own
ported boxed cabinets
what do you suggest, i prefer non trapezoidal as is it harder to do the cuts on the plywood, a rectangular box will be better
any pointers ?
i plan to furnish the box with neodymium drivers
and use 1/2 plywood with internal bracing
to make the box not too heavy
3015LF or 15NDL76 to say some in paralleled to get 4 ohms per cab
Inductor 6th February 2013 08:07 AM
EMINENCE KAPPALITE 3015 LF has a better low end in a >135L / 4.8ft³ box (each driver).
mr. doom 6th February 2013 01:59 PM
What amp will you use?
What type of music?
What size of box.
The FatalPro 18" neo is not much more expensive.
jbell 6th February 2013 02:12 PM
If you are going to dual reflex -- think PPSL.
maxo 6th February 2013 06:53 PM
Originally Posted by mr. doom (http://www.diyaudio.com/forums/subwoofers/229416-dual-15-reflex-sub-help-post3358354.html#post3358354)
What type of music?
What size of box.
Music is ballad/pop with 2 live singers, keyboards and drum machines
live electric bass sometimes, but mostly 2 singers with arranger keyboard and drum machines
the size of the box , i like the size of that dual 15 from community
so i prefer a dual 15 than a dual 18 ,,, too large
mostly indoor venues
i have 2 peavey pr12 and with the mid highs spl's i am ok
but i lack the low end ompth so thats why i am looking to make a sub
i have a crown XLS drivecore 2000
and dbx driverack PA... at last... Sigh!
maxo 6th February 2013 06:54 PM
Originally Posted by jbell (http://www.diyaudio.com/forums/subwoofers/229416-dual-15-reflex-sub-help-post3358364.html#post3358364)
Jbell,
any ponters , i found this
http://www.audioasylum.com/cgi/vt.mpl?f=hug&m=161240
weltersys 6th February 2013 07:39 PM
More information here:
http://www.diyaudio.com/forums/subwo...nclosures.html
maxo 6th February 2013 08:46 PM
Originally Posted by weltersys (http://www.diyaudio.com/forums/subwoofers/229416-dual-15-reflex-sub-help-post3358777.html#post3358777)
Welter
fact is that i do not want ( and dont have the knowledge ) to sim and test designs
i want something that is already designed and with plans
so i just build and use
any plans that you can link me to for some PPSL tried and good design
weltersys 6th February 2013 08:57 PM
Originally Posted by maxo (http://www.diyaudio.com/forums/subwoofers/229416-dual-15-reflex-sub-help-post3358892.html#post3358892)
Welter
DJK's designs in the two links are good.
If you are going to use 1/2", use a lot of bracing.
maxo 6th February 2013 10:48 PM
Originally Posted by weltersys (http://www.diyaudio.com/forums/subwoofers/229416-dual-15-reflex-sub-help-post3358903.html#post3358903)
Welter can you paste the links to the right post
i tried to follow but filtering the info from 34 pages
is not easy
Resources saved on this page: MySQL 18.75%
