dual 15" Reflex Sub help - Page 7 - diyAudio
Old 14th February 2013, 08:47 PM   #61
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Default Taking the woof out of the woofer...
Originally Posted by maxo View Post
and that means ..........
It's not much of a sub anymore.
Dan
Old 14th February 2013, 08:54 PM   #62
maxo is offline maxo  United States
on post 55
i notice that the response at 40hz is just 90db
the rollof starts at 60hz
that means that you can tweak the width of the ss15
or the normal ss15 rolls of at 60hz
now i am worst that when i started
Old 14th February 2013, 09:23 PM   #63
weltersys's Avatar
on post 55
You are worse off now because you originally stated you wanted 35 Hz response, then started considering "subs" that roll off almost an octave above that . Zero in on what is important to you.
My dual Lab12 front loaded box is similar size to the SS15, and kills the SS15 below 50 Hz or so, the SS15 kills the dual Lab 12 above.
The Keystone kills both in all respects, but is almost twice the size.
Art
Old 14th February 2013, 09:35 PM   #64
tb46 is offline tb46  United States
Hi NEO Dan,
If you and others here would take the time to look through the singlesheet thread you would notice, that the measured response of this sub is lower than the Hornresp response indicates. Ultimately nobody can say what this, or any other, sub will do for a specific person in a specific application.
Juhazi's comment in Post #58 is completely of the mark, as I tried to point out in Post #60.
Maxo's question "...and that means....." just shows that he is quite confused by now. Which is somewhat understandable, partially because of comments like yours in Post #61.
Maxo,
I would not go beyound reducing the width of the SS15 by more than 3". For the application you described this sounds like a very nice subwoofer. If you want something that goes lower you will have to look at the Xoc1 TH18 or at Art's (Weltersys) Keystone; or, you have to go with a different technology, e.g.: a vented (bass reflex) enclosure, but, you'll loose overall SPL v. package size v. weight.
Well, have a nice day Y'all,
Oliver
Old 14th February 2013, 09:38 PM   #65
Oliver thanks for the heads up and
looks like i will end making one slim ss15 and then one slim keystone and see what i like better
and then i can make the pair or 3 more to have 4
Hey art, you are right but at least
i have 3 choices, and look like the keystone is the one who flips me the eye but still in love with the ss15... damn i am not a man of a single woman
so can i make a slim keystone with 3 or 4 inches less wide and compensate on the height
or that is blasphemy
Old 14th February 2013, 10:00 PM   #66
weltersys's Avatar
Raising the cabinet height would lengthen the path length, which would lower the Fb slightly, and lower the sensitivity.
Old 14th February 2013, 10:00 PM   #67
NEO Dan's Avatar
Just build two full size 18SW115 loaded keystones and forget the rest.
Dan
Old 14th February 2013, 10:02 PM   #68
Dan,
would my power amp in 4 ohms maybe actually like 3
because of the driver not being 8 ohms
can at least make some noise with a pair of keystones
as i have a crown drivecore XLS 2000
wish i got a qsc PL380
Old 14th February 2013, 10:03 PM   #69
Dan,
as i have a crown drivecore XLS 2000 that is rated at 650 watts at 4 ohms
Old 14th February 2013, 10:09 PM   #70
NEO Dan's Avatar
With limited power, you can use a 15" like the 15HP1030 or 15HP1060. But ultimately building with the 18SW115 is going to allow you to buy a "real" amp. 4-cabs of lesser performance is less satisfying than two that really work. And less to haul around...
Dan
Dual 15" Subwoofer project complete twin turbo Subwoofers 31 29th August 2013 06:10 PM
Dual 15" party speaker Cal Weldon Swap Meet 2 15th April 2008 11:28 PM
Tannoy 15" Dual Concentric - FS in NZ poynton Swap Meet 6 3rd June 2007 12:49 AM
What Type Of Enclousure For Dual 15" Earthquakes? Tony.ca Subwoofers 5 3rd March 2004 11:52 PM
cabinet suggestions for dual 15" jbl woofers djquick_silver Multi-Way 4 24th September 2002 06:56 AM
Copyright 1999-2017 diyAudio
