dual 15" Reflex Sub help
Old 14th February 2013, 01:07 AM   #51
m R g S r is offline m R g S r  United States
He has stated it in the keystone thread hasn't he?
Old 14th February 2013, 01:08 AM   #52
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
I think you are correct. I was just off looking for that but couldn't remember where...
Dan
Old 14th February 2013, 01:23 AM   #53
In the thread Maxo posted a link to (guess Maxo isn't reading anything lol)
"The BC18SW115 in the test box are pictured next to a box exactly double the size of the 2x12.
That box, the Keystone sub, is about 6 dB more efficient than the bass reflex designs using either the Lab 12 or the BC18SW115-4 with the same low corner."
Old 14th February 2013, 01:42 PM   #54
maxo is offline maxo  United States
Sorry guys, i was reading too much and get sidetracked by the job
( lol ) actually bosses say that you are sidetracked by the "audio crap"...
they dont understand and never will and audio spirit that struggle to be free
so i narrowed my quest to the Keystone and the SS15
now i am wondering if i can cut dimmensions by 2 or 3 inches
on width or deepth and compensate on height to maintain the volume of the box
is there any comparision around here about a keystone and a ss15
btw, there is a cubo sub also around
does anyone have have seen it
Old 14th February 2013, 02:42 PM   #55
tb46 is offline tb46  United States
Hi maxo,
"...now i am wondering if i can cut dimmensions by 2 or 3 inches
on width ..."
I did that in the singlesheet thread (singlesheet same as SS15), don't remember where or when, but anyhow, here are comparisons between the Hornresp SPL plot for a standard SS15 v. narrowed boxes (narrowed by 1.5"/3"/5"). (The faint trace in the "background" is the reduced box size SPL.) No make-up necessary. Stay w/ the Eminence 3015LF, and the recommended 1/2"nom plywood.
Oliver
Old 14th February 2013, 02:47 PM   #56
Thanks oliver,
on the graph with the 5" more narrow cab
you can see a little dip around 100hz of like 2 -3 db
so i can live with that , that dip you can compensate with eq i think right ?
anyway i will cross my tops at 120 or 150 as thye are 12's
THanks Dude you da man for making those graphs possible!!
Max.
Old 14th February 2013, 03:08 PM   #57
Hi maxo,
As far as eq is concerned the main thing to watch for is the high pass (low cut) to keep the bottom excursion in check.
Just make sure that your speaker fits inside the box. The 3015LF spec sheet says: Overall Diameter 15.32", 389.1mm. :-)
Oliver
Old 14th February 2013, 06:21 PM   #58
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
According to the sim this woofer has F3 at 50 Hz. Try to get a graph of "Combined spl" output which adds the sound coming from the port at tuning Fq!
AINOgradient speaker project
Old 14th February 2013, 06:37 PM   #59
and that means ..........
Old 14th February 2013, 06:44 PM   #60
Hi Juhazi,
If you are referring to the SPL plots in Post #55 they are correct; they are not for a vented (bass-reflex) enclosure, they are for a tapped horn. I recommend you take a look at the Single sheet TH challenge .
Oliver
dual 15" Reflex Sub helpHide this!Advertise here!
Dual 15" Subwoofer project complete twin turbo Subwoofers 31 29th August 2013 06:10 PM
Dual 15" party speaker Cal Weldon Swap Meet 2 15th April 2008 11:28 PM
Tannoy 15" Dual Concentric - FS in NZ poynton Swap Meet 6 3rd June 2007 12:49 AM
What Type Of Enclousure For Dual 15" Earthquakes? Tony.ca Subwoofers 5 3rd March 2004 11:52 PM
cabinet suggestions for dual 15" jbl woofers djquick_silver Multi-Way 4 24th September 2002 06:56 AM
