#31 |
#32 |
#33 |
bump
Jim, 48" max height , 20" width and 22 deep, low extension i dont care , i mean 40hz or 35 hz low is the most i want, it is for PA not for cinema weight i dont care for the given dimensions, altough light magnet drivers are a plus, so i will like to have both options in case i want to go with the more expensive route Now, i was thinking instead of a dual 15 or dual 12 , singles like the SS15 but smaller at the expense of injecting more power to them what about a mini SS15, with dual 12 drivers or single 12" driver Lab 12's i heard a lot or 3012LF, another tought is the 3015 Tqw that bjorno posted the size is perfect but can that thing be fitted with dual 12 to get some more spl out of them or i just a plain no and you need just a more powerful 15" driver some ideas i just come up with |
#34 | |
Regards, Dan |
#35 |
Thing is that the plans are scatered all over the place on the keystone thread
for example on the SS15 by jbell thread he maintain like an index on the 1st post with links of the plans and stuff so you can easily print and start you project |
#36 |
#37 |
yeah i found them but plans are not user friendly
#38 |
Dude put in a little effort to get this done lol
I vote for the keystone design. No I've never heard Art's cabinet, but I'm sure it will cover the freq range you want, (35hz on up) with the power and DSP you currently have available, with ease. A pair of them will really rock most places ![]() ![]() These are just screen shots from my iPad so they're not clear, but save them to your comp and print out in full size, they should be plenty easy to read and follow, and jot down notes as you're building in the workshop. Last edited by m R g S r; 13th February 2013 at 03:20 AM. |
#39 |
As I mentioned in the pm, a CS-30 style box might be better suited for you. Well not one, but four. Two placed wherever you would like. The other two next to or on top of them.
Post 9 of this thread is a rough plan on what the box should look like. Featherweight Title Fight (4) Lab 12's plus some wood should be around $800 usd. Using 1/2" Baltic birch with bracing should keep weight down on those, and portability as well. |
#40 |
ic, so now, is keystone or CS-30.... i dont like lab 12 for the weight but you cant have all in life
what would be pros and cons of the CS-30 vs Keystone |
| Dual 15" Subwoofer project complete | twin turbo | Subwoofers | 17 | 18th January 2013 08:55 PM |
| Dual 15" party speaker | Cal Weldon | Swap Meet | 2 | 15th April 2008 11:28 PM |
| Tannoy 15" Dual Concentric - FS in NZ | poynton | Swap Meet | 6 | 3rd June 2007 12:49 AM |
| What Type Of Enclousure For Dual 15" Earthquakes? | Tony.ca | Subwoofers | 5 | 3rd March 2004 11:52 PM |
| cabinet suggestions for dual 15" jbl woofers | djquick_silver | Multi-Way | 4 | 24th September 2002 06:56 AM |
