dual 15" Reflex Sub help
Old 7th February 2013, 02:44 PM   #11
maxo is offline maxo  United States
Ok i have found this plans on the 18sound website
is a dual 15" push pull design
Eighteen Sound Kits
Old 7th February 2013, 03:23 PM   #12
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
I checked that plan. To me that's no sub. The response drops and there is no output below 30Hz. That is a PA bass cab to me.
You must decide by yourself, what kind of output you want. Music doesn't have much below 31Hz but movies with a LFE audio channel do.
How much spl do you want? Do you live in an apartment or a house. How big room, what material are walls? What size is the room? Do you want to scare the neighbors?
If you need a really low-going HT sub, it must be a really low-tuned BR or closed box system. Then give some max size and try to find driver elements that work well in that composition. Simulation are a good help here. With well matched parts you'll get lots of good sub-bass and bass (25-100Hz) with less than 100W.
Sorry, I don't want to give examples, there are milllion ways to go.
Please google for Sonotube sub or LLT sub (usually 1x15")
Personally I go the easy way with large closed cabs now. I'm not happy with BR-subs.
AINOgradient speaker project
Old 7th February 2013, 03:27 PM   #13
Juhazi,
i think you missed this info that i posted on an earlier post on this thread
Music is ballad/pop with 2 live singers, keyboards and drum machines
live electric bass sometimes, but mostly 2 singers with arranger keyboard and drum machines
the size of the box , i like the size of that dual 15 from community
so i prefer a dual 15 than a dual 18 ,,, too large
mostly indoor venues 100-250 people
i have 2 peavey pr12 and with the mid highs spl's i am ok
but i lack the low end ompth so thats why i am looking to make a sub
i have a crown XLS drivecore 2000
and dbx driverack PA... at last... Sigh!
No cinema sound.. PA sound
Old 7th February 2013, 04:03 PM   #14
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by maxo View Post
Welter can you paste the links to the right post
i tried to follow but filtering the info from 34 pages
is not easy
I prefer DJK's slot load designs to the 18 sound PP, which wastes too much space for the plenum, reducing effective cabinet volume and lessening the positive effects of PP.
DJK's plans are in the second and third post, with links to more designs:
High Efficiency Speaker Asylum
And you may want to read my comments in post #7 .
Art
Old 7th February 2013, 04:19 PM   #15
Art,
i only see 2 posts on the link you gave me...
i am missing something
Old 7th February 2013, 04:48 PM   #16
weltersys's Avatar
Art,
That's weird, something went wrong when I copied the link.
Use the link you provided in post #6.
Old 7th February 2013, 04:52 PM   #17
Cant find the plans
and recommended drivers
Old 7th February 2013, 04:55 PM   #18
jbell is offline jbell  United States
If you really want a PPSL instead of a TH, like a SS15, I can whip up drawings a dual 15 on something cheap, like the dayton pa380, or something like that, in 200liters tuned to 40hz. It should do low to possibly mid 120's. The push pull slot load would be a ton cleaner than just a basic reflex cabinet, but not much more involved in construction.
You have a budget for neo drivers? and are planning on using one channel of your amp for subs, and one channel for your pair of tops?
Old 7th February 2013, 05:00 PM   #19
weltersys's Avatar
Cant find the plans
From your link in post #6:
Old 7th February 2013, 05:05 PM   #20
weltersys's Avatar
Jim,
Did you do any testing to confirm what "a ton cleaner" actually is in THD% ?
Art
dual 15" Reflex Sub helpHide this!Advertise here!
Dual 15" Subwoofer project complete twin turbo Subwoofers 31 29th August 2013 07:10 PM
Dual 15" party speaker Cal Weldon Swap Meet 2 16th April 2008 12:28 AM
Tannoy 15" Dual Concentric - FS in NZ poynton Swap Meet 6 3rd June 2007 01:49 AM
What Type Of Enclousure For Dual 15" Earthquakes? Tony.ca Subwoofers 5 4th March 2004 12:52 AM
cabinet suggestions for dual 15" jbl woofers djquick_silver Multi-Way 4 24th September 2002 07:56 AM
