Beach Radio v5! (Sealed 3015LF sub)
Old 21st February 2013, 12:47 AM   #71
m R g S r is offline m R g S r  United States
Amps mounted. Trying to figure out wiring with what I had...
Made it all work. Everything secure
Front view. Ports secured and tweeter holes done.
Just barely was able to squeeze it all in there!
Old 21st February 2013, 07:50 PM   #72
So I think I'm going to just go with 4 of these, for $240 plus shipping they should last me a very long time. And if not on this project ill have them for years on other projects.
http://evolveelectrics.com/PDF/CALB/CALB_40AH.pdf
Old 21st February 2013, 08:05 PM   #73
weltersys is offline weltersys  United States
weltersys's Avatar
As long as you pay attention to not letting any of the cells get charged over 3.6V, or discharged below 2.8V, the batteries may outlast the rest of the system.
Old 21st February 2013, 08:35 PM   #74
That's what I figure. And ill only have the panels connected when the radio is on, so current draw will deff exceed the charging current.
Can't wait to fire this up! Might finish construction tomorrow if I have time.
Old 22nd February 2013, 01:53 AM   #75
So it looks like this battery is $262 shipped to me. With the nickel connecting bars included.
LiFePO4 Prismatic Battery: 12.8V 40Ah , 12V 40Ah lithium battery
I think I'll just do that. Says in stock too.
Old 22nd February 2013, 04:01 PM   #76
weltersys's Avatar
Those appear to be the same GBS batteries as I purchased from EVolve.
I like the four screw battery posts better than the single post, but the specs are not as good as the other brand.
Build quality seemed good, only time will tell how many recharges they will do.
Been too cold for me to feel like riding the bike, so have not put on any more miles since post #9.
Old 22nd February 2013, 09:15 PM   #77
Got some more stuff done. Just have to do finishing touches after this!
It fits!
Front view untainted
Quick coat of paint to seal the wood
Old 23rd February 2013, 08:33 AM   #78
TMHutson is offline TMHutson  United States
TMHutson's Avatar
I like the progress. That thing is awesome...
I am curious to see how the power works out.
I have friends that go on hikes in the desert.
Would be fun to make a solar powered stereo for the back of the suburban
So we can bump tunes while relaxing after the hike...
Old 23rd February 2013, 12:56 PM   #79
Thanks man.
Me too! I keeping my fingers crossed that it will be enough to play all out for a few hours. From my rough calculations it should be able to, just depends on how bass heavy the tracks are I guess.
Old 23rd February 2013, 03:13 PM   #80
Its Alive!!!
Grills on
Thinking of a grill solution for the 15". Just have to screw the top on, make some kind of prop to hold the top open when the radio is on its side, and inject a little more foam into the cooler between the Baltic birch and the plastic cooler walls.
Impression? It sounds pretty good for what it is! Plenty of bass to go with the midranges, tested to full output and a bunch of stuff was shaking in the workshop, no chuffing from the ports.
I hear a slight buzzing inside the box, gotta insulate some of the wires and plastic stuff inside from buzzing. Maybe it was the cooler walls too.
But basically just finishing touches left for her! I'm excited for it to get sunny and warm here in NY and test this stuff outdoors!
Beach Radio v5! (Sealed 3015LF sub)Hide this!Advertise here!
What's up with the 3015lf pricing?? m R g S r Subwoofers 50 28th April 2015 09:54 AM
TWO 3015lf screamersusa Swap Meet 1 21st January 2013 12:24 AM
3015lf for HT? m R g S r Subwoofers 27 3rd May 2011 07:04 PM
Subwoofers for Beach Radio... m R g S r Subwoofers 50 24th February 2011 11:37 PM
3015lf? mike james 533 Subwoofers 29 18th April 2010 01:00 AM
