Beach Radio v5! (Sealed 3015LF sub)
Old 11th February 2013, 09:46 PM   #61
m R g S r is offline m R g S r  United States
Took a lot of cutting and melting plastic with the heat gun, but I got the larger panel to fit inside the top of the cooler!
Taped the top with aluminum tape (stuff is super sticky) and got it ready to spray some expanding foam inside to try and lock the solar panel in place
Clamped in place and sprayed some foam in there! I'll see how it comes out tomorrow!
And re-glued the cheapo horn tweeters, the plastic waveguide separated from the compression driver
Old 14th February 2013, 01:59 AM   #62
Grabbed the wood and got started on the cabinet.
Crossovers in position, mid enclosures pretty much built.
The housing on the left above the crossover is for the head unit.
Total calculated internal volume before amps, subwoofer displacement and port tube subtraction is 2.456 ft ^3.
Old 14th February 2013, 02:09 AM   #63
So after two 11" ports made of schedule 40 PVC and amps and driver displacement, I figure around 2.15-2.2 cubic feet
With dual 3" ports 11" long that should be roughly 36-37hz tuning. That shoud do and with only a 30hz high pass I think I'll still be fine given the wattage ill be running.
Old 14th February 2013, 02:12 AM   #64
von Ah is offline von Ah  United States
von Ah's Avatar
Wicked project. I love it.
Old 16th February 2013, 08:27 AM   #65
KMossman is offline KMossman  China
KMossman's Avatar
Send a message via Yahoo to KMossman Beach Radio v5! (Sealed 3015LF sub)
sadly, I can not see the photos
Getting back into business, though non-audio related. Have excellent contacts for NEW [OEM] Russian and Chinese tubes. Custom chassis, and parts [MOQ applies]
Old 16th February 2013, 03:47 PM   #66
Grabbed the breifcase solar panel. I now have 3 panels totaling roughly 30 watts.
Old 16th February 2013, 04:32 PM   #67
KMossman's Avatar
CALCULATED or actual?
Old 16th February 2013, 04:47 PM   #68
Just estimating. 2 13 watt panels and 1 10 watt. We shall see what I actually pull from them once we get some warm weather / sun here in NY.
Sorry it's 1 15 watt, 1 13 watt, 1 10 watt.
Old 16th February 2013, 07:06 PM   #69
Two 35ah batteries in parallel would give me 70ah right?
Any reason not to use these two in parallel? (Same 50lbs total weight, both will fit in the duffle bag I have.....)
$141 shipped to me.
http://www.apexbattery.com/12v-35-ah...Fcyj4AodC3MAKA
Old 16th February 2013, 07:20 PM   #70
weltersys is offline weltersys  United States
weltersys's Avatar
On paper, a pair will give you 70AH to full depletion.
No reason other than weight and expense not to use two.
That said, taking lead acid batteries below 50% charge (12.06 volts after a rest) shortens battery life quite a bit.
The group 27 marine lead acid batteries I used on my trike did not hold much charge after only 4 or five deep discharges.
Beach Radio v5! (Sealed 3015LF sub)Hide this!Advertise here!
What's up with the 3015lf pricing?? m R g S r Subwoofers 50 28th April 2015 09:54 AM
TWO 3015lf screamersusa Swap Meet 1 21st January 2013 12:24 AM
3015lf for HT? m R g S r Subwoofers 27 3rd May 2011 07:04 PM
Subwoofers for Beach Radio... m R g S r Subwoofers 50 24th February 2011 11:37 PM
3015lf? mike james 533 Subwoofers 29 18th April 2010 01:00 AM
