Beach Radio v5! (Sealed 3015LF sub)
Old 29th May 2013, 07:31 PM   #101
maxo is offline maxo  United States
Originally Posted by m R g S r View Post
I purchased the suggested smart charger for the battery It does full charge in 5.6 hours I believe? The battery and charger were $310 shipped to me.
what is the playtime duration in hours at war volume
Old 29th May 2013, 09:00 PM   #102
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by maxo View Post
Art. that is a lot of info you got there !
Did a lot of research before spending the big bucks on LiFePO4.
It is one thing to run out of tunes, quite another to push a 165 pound electric motorcyle home up hill ..
Old 30th May 2013, 12:49 AM   #103
m R g S r is offline m R g S r  United States
Kind of hard to calculate, lots of factors Involved. Guess ill find out once we hit the beach! I'm thinking this Sunday if the weather is nice here in NY
Old 30th May 2013, 12:54 AM   #104
Originally Posted by weltersys View Post
The 40 amp LiFePO4 battery pack can use as much as a 40 amp charger could put out (1C), but can be charged at any fraction of that charge rate.
A dedicated charger designed for LiFePO4 is the safest bet, as the individual cells must be charged at no more than 3.8 volts (15.2 volts for a nominal 12 V series pack of four) or they can suffer permanent damage.
A static voltage around 13.6 is fully charged on the LiFePO4.
Many "normal" 12v chargers can be used, but most will not bring the LiFePO4 battery pack up to full charge. But the 80% discharge rate far exceeds the safe discharge of 50% on a lead acid battery, even if the LiFePO4 is only charged to 12.6 v("full charge" on a LA) it will still carry a lot more usable juice.
Art
Art do you have any tables that show voltage vs charge percentage for LiFe batteries? Just curios so I know what percentage I'm at while using the radio....
I know that may be tricky when the radio is in use, because most tables are for resting voltage, not in use.
Just from the few times I checked over the weekend while using the radio, with the panels connected, in full sun, the voltage with the LiFe battery was still higher than even the big lead acid batteries were at full charge, In full sun!
Old 30th May 2013, 01:17 AM   #105
bitSmasher is offline bitSmasher  Australia
bitSmasher's Avatar
Could be worse, run out of tunes and beer, and have to push a 165lb system home
Old 30th May 2013, 01:59 AM   #106
turbodawg is offline turbodawg
Interesting stuff. My budget portable setup is a PPI P900.4 with a 12v 35ah SLA, bridged onto a single 4ohm sub and bridged to a 8ohm top. Passive preamp, PAC LC-1, with a sansa clip+ running rockbox, volume up to +6. Sub turned up all the way on the gains with a high pass well below tuning and the top half way up, at max volume runs for about 3 hours on a full charge, then the voltage slumps enough for the amp to cut out. Rocks pretty good, lol.
This weekend we ran out of juice, so we plugged in a 12v 6A charger in parallel to the battery to a honda eu1000 generator. Had to increase the highpass a good bit, and cut the volume to about +2 or +3 on the clip+, to keep the amp from cutting out. In the future, I will adjust the high pass on the sub more carefully, to around tuning, to avoid wasting power.
So figure I'm drawing ~12A at max output, or ~150w, which sounds about right, and (obviously) ~6A off the charger.
Figure your amps into your speakers will draw about 80-100w at full music output, so with the solar cells and battery, I'm going to guess a solid 7-8 hours!!!
Old 30th May 2013, 06:34 AM   #107
bitSmasher's Avatar
Those things have a 12V output, don't they?
Might be worth your time, if you'll be near one again, to make up a specific cable for running your rig off an EU generator
Old 30th May 2013, 03:38 PM   #108
Yes...didn't notice before, though my friend may have mentioned it in passing. Looks like it's rated for 8A. Thanks!!
Old 30th May 2013, 04:02 PM   #109
chris661 is offline chris661  United Kingdom
chris661's Avatar
My rough guess for these things is...
full-tilt playback time in hours = (battery capacity in Ah)/(system quiescent current + 1/10 x maximum current draw, minus charge current from solar panels etc)
Reasoning is that, for most music, the peak-to-average ratio is around 10dB for a lot of music.
If you take 1/10 of the maximum current to be the average, the peaks will be at the onset of clipping, which is what I'd call full-tilt, as there's no more clean output to be had.
Chris
Old 30th May 2013, 04:05 PM   #110
That may be roughly accurate for no solar panels involved, but throw them into the mix, turning the volume up or down etc things change. So that's why I said very hard to get a good idea of how long it will last.
Beach Radio v5! (Sealed 3015LF sub)Hide this!Advertise here!
What's up with the 3015lf pricing?? m R g S r Subwoofers 50 28th April 2015 10:54 AM
TWO 3015lf screamersusa Swap Meet 1 21st January 2013 01:24 AM
3015lf for HT? m R g S r Subwoofers 27 3rd May 2011 08:04 PM
Subwoofers for Beach Radio... m R g S r Subwoofers 50 25th February 2011 12:37 AM
3015lf? mike james 533 Subwoofers 29 18th April 2010 02:00 AM
