Sub project for PA - Help needed
Old 7th February 2013, 05:32 PM   #41
m R g S r is offline m R g S r  United States
Originally Posted by tb46 View Post
Hi Y'all,
Here is the Hornresp for the combination of Bertha horn with Levan extension. The horn path could possibly benefit from a little more detail work, but I don't think it would make a difference in the output. This is for a single JBL 2242H @ ~ Xmax. It's definitely a manly sub.
I was going to say, having heard them in full force, the double woofer, 48" high version, with 5000rms each, 4 of them one in each corner of the dance floor, there's no way that's a 50hz sub. These things are absolute MONSTERS!
Old 7th February 2013, 05:33 PM   #42
turbodawg is offline turbodawg
As a race car builder, you must know that the only replacement for displacement is an increase in RPM
David,
Although an amazing feat, there is still no replacement for displacement.
Top fuel dragsters are getting around 8500 bhp from 8 liters, a slightly better power to displacement ratio- the 1.5 liter would need to do 1594 bhp to equal that.
And the top fuelers rev to around 8250 RPM, probably several thousand below the turbo-charged Formula One engines.
Of course the top fuel engine would not last through a Formula One race...
Art
Top fuel dragsters are forced induction too, Art.
Old 7th February 2013, 05:42 PM   #43
Oliver,
Manly in size, not so manly in output. Can't win 'em all.
BTY, Short Fuse Lee has left the post to the ones willing to do some comparative work.
Art
You sure art? I'm not talking about the JBL loaded sub, but the output was stunning from these things. Yes I know it is indoors but the output was literally PAINFUL to both my body and head / ears.
The (40) 18" drivers arrayed from a live stage (20 Martin Audio ws218x) couldn't even touch the output of these And yes they were being run all out with Victor Calderone spinning, the sound guy Jason Ojeda confirmed it.
Old 7th February 2013, 05:44 PM   #44
weltersys is offline weltersys  United States
weltersys's Avatar
So was the GMC 671 diesel engine in the bus my dad drove our family around the country in.
That had some heavy parts...
Old 7th February 2013, 05:49 PM   #45
weltersys's Avatar
I don't doubt they are loud, I was just comparing Olivers sim of Lee's Berthoid to the Keystone, it is more than twice as big with less output on everything but below 35 Hz.
Old 7th February 2013, 05:53 PM   #46
Point being, most knowledgeable car enthusisasts don't go around saying "there's no replacement for displacement", because forced induction is typically regarded by everyone as the replacement for displacement.
As a race car builder, you must know that the only replacement for displacement is an increase in RPM, not possible in subwoofers.
Old 7th February 2013, 06:31 PM   #47
Turbo / blower on top of a big V8 =
Ask SpinMonster. His vette was a beast
Old 7th February 2013, 10:43 PM   #48
weltersys's Avatar
Forced induction is a way to get more power out of an engine, as David McBean said, it's like horn loading.
A larger displacement forced induction engine will have a larger power output, just as a larger displacement loudspeaker will have more SPL output, regardless of the enclosure type.
Old 7th February 2013, 11:02 PM   #49
jacq. is offline jacq.  Canada
Lee Interesting reading;
http://www.electrovoice.com/download...s%20v04%20.pdf
Old 8th February 2013, 07:34 AM   #50
David McBean is offline David McBean  Australia
Top fuel dragsters are getting around 8500 bhp from 8 liters, a slightly better power to displacement ratio - the 1.5 liter would need to do 1594 bhp to equal that.
Formula One uses conventional petrol / gasoline. A top fuel dragster uses up to 90% nitromethane / 10% methanol. This at least doubles the power.
Kind regards,
David
www.hornresp.net
Sub project for PA - Help neededHide this!Advertise here!
Bigger than needed pa enclosures. holger honda Multi-Way 9 14th January 2014 06:15 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 1 17th September 2011 04:59 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 0 17th September 2011 01:39 PM
Precision PA conversion help needed PRNDL Tubes / Valves 10 6th December 2007 06:14 PM
Hello from PA! (Project suggestions?) DIYStudent Introductions 3 29th August 2006 08:18 AM
Copyright ©1999-2017 diyAudio
