Sub project for PA - Help needed
Old 5th February 2013, 05:15 PM   #11
more10 is offline more10  Sweden
Hi Lee
You can run Hornresp in Wine if you have an Intel Mac. Hornresp
You can also run akabak in wine.
Start with Hornresp and export to akabak where you can add more horn segments, hornresp is limited to 4 segments. It will not do much diffence though, 4 segments will give you a very good simulation.
Old 5th February 2013, 05:30 PM   #12
Inductor is offline Inductor  Portugal
Inductor's Avatar
Originally Posted by Lee in Montreal View Post
BTW When you mention that the 2242 is "not the best", are you refering as "not he best for home duty" or "not the best for PA". Those would be two very different requirements. The 2242 has a relatively low Qts (0.28) and a strong motor. The venting allows for great cooling. This is perhaps the best sound reinforcement woofer JBL has made in decades. And that's why it is widely used on dance floors. Both on bass reflex cabinets and horn loaded ones.
I only meant the JBL 2242H not good for horns. Take it at face value (simulation program, not my experience). I only see it being used as (front) bass reflex enclosures.
Old 5th February 2013, 05:33 PM   #13
Lee
Can you give the cross section areas and lengths in centimeters? Ill do the simulation for you
Old 5th February 2013, 05:42 PM   #14
weltersys is offline weltersys  United States
weltersys's Avatar
I checked the T/S specs on the BC woofer and not much is available. All sites that sell it have the same minimal info. 96db efficiency compared to the JBL's 2242 of 99db.
You can download spec sheets with full TS parameters for all B&C drivers here:
B&C SPEAKERS
Sensitivity specifications are pretty useless for comparing bass drivers, for instance a Lab 12 is only rated at 89.2 one watt one meter, but a pair are over 100 dB in the LabSub horn design.
And sensitivity does not say what will happen at high power- a pair of Lab 12s are more sensitive in my Keystone sub design than the B&C18SW115, but the B&C can go quite a bit louder because it has hardly any thermal compression at double the power the Labs can take.
Old 5th February 2013, 06:23 PM   #15
Inductor's Avatar
I'm not sure if this is of any help (in metric/cm), 10.5 ft horn simulation for JBL 2242H.
Old 5th February 2013, 07:10 PM   #16
weltersys's Avatar
So, according to the sim, is the F3/Fb of that monster only 49 Hz?
Old 5th February 2013, 07:13 PM   #17
Inductor's Avatar
Thanks for posting the reference JBL ASH6118 Horn-Loaded Subwoofer for the JBL 2242H.
JBL :: Product
http://www.jblpro.com/BackOffice/Pro...ts/ASH6118.pdf
JBL 2242, as used in the ASH-6118WH horn loaded sub is flat to 30Hz with high efficiency.
JBL ASH-6118WH Specifications:
Frequency Response (3 dB):1cabinet: 30 Hz 200 Hz,
Do you see that expressed in the graphics pic of the pdf (or is it me??).
File Type: jpg ASH6118 Maximum Impact Horn-Loaded Subwoofer.jpg (105.2 KB, 43 views)
Old 5th February 2013, 07:27 PM   #18
weltersys's Avatar
JBL written "Specifications" seldom seem to match the graphs.
Looks like 4 of ASH6118 do a good job getting to 30 Hz, but a single rolls off below 40 Hz.
Old 5th February 2013, 07:27 PM   #19
Inductor's Avatar
It's not very "flat" whatever that means , it's only half-infrasound to shake half of the crowd (make it double 2x20Hz=40Hz an octave above).
Old 5th February 2013, 07:45 PM   #20
Inductor's Avatar
1.5m / 4ft 11 1⁄16in horn simulation for JBL 2242H
Sub project for PA - Help neededHide this!Advertise here!
Bigger than needed pa enclosures. holger honda Multi-Way 9 14th January 2014 07:15 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 1 17th September 2011 05:59 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 0 17th September 2011 02:39 PM
Precision PA conversion help needed PRNDL Tubes / Valves 10 6th December 2007 07:14 PM
Hello from PA! (Project suggestions?) DIYStudent Introductions 3 29th August 2006 09:18 AM
Copyright ©1999-2017 diyAudio
