Old 2nd February 2013, 04:33 PM   #11
Speedskater's Avatar
That's strange, I thought that I linked directly to the 57 minute sub-woofer presentation rather than the 2 & 1/2 hour meeting.
If my link takes you to the meeting look for the sub-woofer link to the right.
Kevin
Old 2nd February 2013, 04:58 PM   #12
OK, that works. Good stuff!
Old 3rd February 2013, 06:00 AM   #13
Default Another option
Have a look at this, it works pretty well.
DP_woofer_room
Commercial Site: www.HolisticAudio.com
Old 3rd February 2013, 07:21 AM   #14
Originally Posted by tsiros View Post
This is odd.
First, response is flat down to 10 Hz. Second, i don't see any other resonances. Is your room completely cubic, 3 m * 3 m * 3m ?
That was after EQ. The room is heavily trapped (Designed by a proffesional) , but the 25hz area is the only remaining problem with the room.
This is the after EQ in room response after appling the house curve and 80hz LP filter applied. Subs and amps still have a bit left in them.
Old 3rd February 2013, 05:05 PM   #15
You could try a double bass array. Typically you would use more drivers spread across the front and back walls to create a plane wave (google double bass array for examples), but at 25hz 4 subs might be enough. You would put two in the front of the room, two in the back. Have them roughly 1/4 of the room width in from the side walls. Drive the front ones normally with a mono signal. Drive the rear ones with the same signal as the fronts but inverted in polarity and delayed by the propagation time from the front subs to the back subs (if your room is 3m long, about 3/344=0.00872 seconds). The idea is that as the wave from the front subs arrives at the back of the room, the inverted polarity signal is produced and cancels the signal from the front subs so it is no longer heard. You will probably have to re-eq after doing this to get it to sound right.
Old 5th February 2013, 10:04 AM   #16
Hi John,
Thanks for the info, I have seen that kind of approach before, not sure it is doing in my room. I have 4 subs in an IB at the front, but I will also have 3 IB subs in the back right hand side of the room. I can't get them in the same position as the fronts though. That last graph is with only the 4 subs at the front playing.
Old 6th February 2013, 10:10 AM   #17
Sorry to be late to the interesting discussion.
First, if I had only your 25-Hz "problem" I'd be laughing. Purely a visual/graph thing that only bothers wannebee engineers, I'd guess. Not something any human could hear on any ordinary source. There are few systems that wouldn't sound better with a bump-up at 25 Hz, esp. a bigger boost through the low bass is likely needed to sound right (hint: flat bass sounds lousy).
Except for absolutely heroic architectural treatments, not much can be done to directly grapple with problems like this... a little trim here, a little boost there... many good ideas have been mentioned but the effect in most rooms I've tried is meager.
But I'm with Geddes - who is really repeating the clear chapter in Toole's book. In short, you want something an engineer-at-heart would hate: heterogeneity. Mix and match three or more sub-woofer housings, locations, tuning, dipoles, and so on.
One thing I'd like to ask this forum is whether the heterogeneity technique works better with a single mixed-bass signal or some hodge-podge of the stereo signal found in the source?
Ben
Dennesen ESL tweets, Dayton-Wright ESL (110-3200Hz), mixed-bass Klipschorn w/param EQ plus giant OB using 1960's Stephens woofer
HiFi aspirations since 1956
Old 6th February 2013, 03:09 PM   #18
KaffiMann's Avatar
Seems like a dream response curve to me.
I deal with canceling room modes by using main speakers with multiple BR ports pointing in different directions to cancel modes at specific points in the room. The result is that there is still some gain from the phase variations caused by height/length/width/materials of the room, but it is evenly distributed, no very apparent phase issues, from 33-87hz near flat with no peaks. As opposed to very peaky and clearly audible phase issues from 30-42hz before.
Your frequency response from 0 to 50hz seems very good. I envy you.
Theory and practice.....
Standby mode and speaker turn on delay together? TiGeRGuY Chip Amps 9 6th September 2012 07:55 AM
Is this a room mode? hjf Subwoofers 4 22nd January 2011 02:56 PM
Room EQ notch filters with delay? MBK Multi-Way 9 1st October 2005 03:48 PM
Room mode, so bad bass frequency response (with or without dipole) ;( mbon Multi-Way 2 21st June 2004 05:53 AM
Is placement that important when using two subs in room to cancel out standing waves? The Paulinator Multi-Way 13 17th May 2004 06:30 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
