Small vented subs tuned low
Old 29th January 2013, 10:22 PM   #11
turbodawg is offline turbodawg
Originally Posted by OscarS View Post
That's interesting indeed, because with a worst-case 2.5 ft│ and a 2.5"*15"*24" physical port gives me a standard tuning of 35hz. 27.5" gives me 33 Hz tuning. I am using Akabak to model. I would actually expect to see your box with no higher than 30Hz Fb. Would be interesting to see an actual impedance sweep of your box.
I'm using hornresp and winisd. If I get around to it in the next day or so, I can pull up the models and double check the numbers.
Old 30th January 2013, 05:55 AM   #12
▀art West-VL. is offline ▀art West-VL.  Belgium
▀art West-VL.'s Avatar
Originally Posted by Don Hills View Post
One solution for when ports become too large for the enclosure:
Long port options for subwoofers
Too long ports might have their first port resonance in the band you want to use them.
I aim at a 1st port resonance of at least double the highest frequency I want to use the sub.
So if a sub has to do 18hz - 80hz, I design the first port reonance to be at least 160hz.
Break in your loudspeakers at 35% RMS power Right-click'save as...'
Brown noise mono 192kbps(hit "repeat")
Small vented subs tuned lowHide this!Advertise here!
Multiple-Small-Subs vs A-Few-Large-Subs Eskae Subwoofers 11 21st August 2013 09:17 PM
small(15l) vented bipole with fe127e, possible? Brytnardz Multi-Way 4 8th June 2008 07:58 AM
Very small vented speaker? noobsta Multi-Way 3 9th December 2005 07:05 PM
Considering sealed vs vented for my AV12 subs paulspencer Subwoofers 44 15th December 2004 01:07 PM
Linkwitz correction for TL and vented subs? goldyrathore Multi-Way 7 24th February 2004 07:30 PM
