Can i use this driver for home theater? And what type of cab should i use? ported? bottom ported? back ported?
12" Sub-woofer Max Power 450 watts. Sensitivity 97 dB. Frequency response 40 Hz to 5Khz Impedance 4 or 8 OHMS Magnet Weight 55 Oz. Dual Voice Coil - ASV Aluminium Surrounded by rubber Digital Ready Poly-Injection Cone Cant find more specs anywhere... Last edited by leosep; 28th January 2013 at 05:54 PM. |
#2 |
It's surrounded by rubber and digital ready, so yes.
#3 | |
![]() Advice: a driver with no spec sheet is a signal of low quality. But hey, if you have it already, who cares?! Measure it and you can fit it in a perfect box. |
#4 |
Brand, model, any other markings? Front & rear pictures?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#5 |
LOL40 Hz to 5Khz is more like woofer not a subwoofer ported? bottom ported? back ported?, its your preference. ported,sealed,good, bad .No one can help without Thile Small parameters for ur speaker Sensitivity 97 dB is Fake Surrounded by rubber, Digital Ready. I would love to know, which manufacturer lists specs in such a funny way ![]() Ya if you have it already and dont know anything about it, no sticker, no brand Try it out in sealed enclosure for safer bet may be 1.25- 1.5 cubic feet box |
#6 |
i am very curious to know how can a DVC sub have 4 or 8 OHMS ?
I cant imagine. Is it really possible how ??? |
#7 | |
Or just power one of the 8 ohm coils until it burns up, then a spare is still available .
#8 | |
4 ohm or 8ohm 8 must be series, this means 4+4 ohn then the parallel must be 4 and 4 in parallel giving 2 ohm and hence it should be 2 ohm and 8ohm I dont there are 2 resistance values which sum as 8ohm in sries and 4 in parallel |
#9 |
Thanks for your responses. Is a SoundBarrier 12" sub-woofer Model SBW-12PI
Can it sound something close to a Logitech subwoofer? maybe the X530? Last edited by leosep; 29th January 2013 at 03:38 AM. |
#10 | |
Sound Barrier - Sound Barrier | | Woofers I am sure you already know you need Qtc Qms Fs Vas, numbers like these for this sub. Then put em in the winISD free software and you get a nice box type and size simulation. nice one, X-530 Logitech 25watt subwoofer vs Some 12inch 450watts ![]() lets think 12 inchs will kill the X-530 and then tear its cone apart and then $#%$#^%$# the magnetic **** out of the poor no good Logitech how you plan to power this sub Dont know where you from but i hear ppl recommend 50$ infinity 1262 12 inch frequently. Dayton also has lotts of really nice subs for all price range. Last edited by Amit_112dB; 29th January 2013 at 04:02 AM. |
| Can i use this driver for home subwoofer? | leosep | Subwoofers | 15 | 15th January 2013 10:21 PM |
| FS: Dayton Reference Subwoofer RSS315HF-4 12" Subwoofer Driver | matevana | Swap Meet | 0 | 12th February 2012 02:42 PM |
| Home built subwoofer driver | flyingtele | Subwoofers | 13 | 3rd August 2009 04:28 PM |
| Using Home Subwoofer in Car | joelb | Car Audio | 0 | 25th January 2009 04:34 PM |
| The Best Subwoofer Driver for Home audio Too? | cemmany | Subwoofers | 6 | 7th July 2006 03:32 AM |
