Old 26th January 2013, 03:30 PM   #21
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
Originally Posted by tinitus View Post
I suppose it shows a very low tuned vented box, and what we see is port tuning ?
The port tuning is actually higher than where the peak lies. I would imagine it is the coupling affect of two drivers in addition to using large cabinets for Electrovoice wrote a paper about such a phenomenon 30 years ago.
OMNIFEX
Old 26th January 2013, 06:20 PM   #22
Now I'm even more confused. What are the "two drivers"?
Old 26th January 2013, 06:36 PM   #23
The port tuning is the lowest point of the impedance between the
two peaks, the upper peak is related to driver Fs and the lower
peak something I can't quite put my finger on in physical terms,
but its nothing to do with driver Fs.
Fbox is always higher than Fs except for TL's where the options
make it complicated, and generalisations don't help much.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 27th January 2013, 12:47 AM   #24
OMNIFEX's Avatar
It is very complicated indeed. Cabinet shape, size, wadding, mass air load in the chamber, in addition to the affects of the port offer too many variability’s at times. I think many assume reflex cabinets are simplistic. What they are is more forgiving for mistakes by new designers than building a horn. This is why I literally measure the cabinet instead of assuming simulation design software results is written in stone.
OMNIFEX
Old 27th January 2013, 01:13 AM   #25
Originally Posted by audiomagnate View Post
I have a pair of discontinued Dayton 15" PA woofers I would like to use in a pair of home subwoofers: Dayton Audio PF385-8 15" Cast Frame Driver 4" VC 295-080
Opinions, ideas, comments?
Have a look at STAHL - 'Acebass' Synthesis of Loudspeaker Mechanical Parameters by Electrical Means .
Gave me perfect bass down to 20 Hz with 3 opamps and a couple of components in a 57L ported enclosure with my JBL K140 15" .
Cheers ,
Rens
If you measure, you know; if you guess, you don't
Old 27th January 2013, 11:22 AM   #26
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
Is it wise to electrically "change" or mask physical properties of a driver?
To a certain extent propably yes, but I wonder how much distortion you get at high output.
There are many spekers doing that however, Philips MFB, Acebass, etc. Some subwoofers are claimed to sound good and to have less distortion
motional feedback subwoofer - Google-haku
My DIY speaker history: -74 Philips 3-way, -82 Hifi 85B, -07 Zaph L18, XLS10+PR/Hypex, -08 CSS125FR, -08 Hifitalo AW-7, -08 TangBand FR, -09 MarkK ER18DXT, -13 PPSL470, -13 AINO GRADIENT
Old 27th January 2013, 04:46 PM   #27
Cheers ,
Rens
How does this differ from conventional servos?
Old 31st January 2013, 09:43 PM   #28
Default modifying Daytons
Thanks again streten. The boxes are currently tuned to 35 Hz and I don't like the sound. It's great for rock but other music makes it sound thumpy and resonant. I'll pick up a can of undercoating and give it a shot. My scale is not accurate at those weights so I'll just keep spraying until I get to my desired Fs.
Hi there a: Hope the can of gooope from PE has not arrived yet. Numeous alternatives have been provided that would be better than "spaying till well done" and are not detructive, allowing trying other concepts, if neede. Hope you will post your reults . .....regards, Michael
Old 31st January 2013, 10:06 PM   #29
You may also consider the Linkwitz Transform circuite. At one time Linkwitz sold
these boards but I don't think they are currently avaliable.
Linkwitz Transform Subwoofer Equaliser
Old 5th February 2013, 06:31 PM   #30
badman is offline badman  United States
badman's Avatar
rgds, sreten.
The lower and upper peaks are just the remnants of the Fc peak with the null applied. Move towards true aperiodic and the bandwidth of the tuning increases and eliminates the dual lumps.
Bottom line, the 19hz lump is NOT a lowering of Fs. No standard sealed or vented box lowers Fs.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Lowering B+ voltage blue lander Tubelab 39 18th May 2013 01:42 PM
Lowering B+ in PS h00hbt Tubes / Valves 39 14th February 2011 08:12 PM
lowering Qts MCPete Multi-Way 4 31st December 2008 11:09 PM
Lowering HT waner Tubes / Valves 7 29th May 2006 10:31 AM
lowering the voltage Lowjacker Power Supplies 7 11th March 2006 09:11 AM
Copyright ©1999-2013 diyAudio
