#1 | |
I got a very old woofer unit, JBL's PS-120
![]() This speaker only produce low frequency, range 200hz and below. But it has a fatal problem now ( didn't really notice when it started): When the bass is very strong, the back panel (removeable steel portion, mark with red frame in picture) which has all the circuit attached except driver, it refuse to stay as a flat piece of metal, STARTED to flex back and forth with the speaker cone This make a loud noise that annoys me. ![]() The noise can be reduce to very low level with my hand press strongly against the back panel, but then I wouldn't able to sit down and enjoy my music/video. ![]() Beside, I couldn't supress it with the strength of hands only I need to use my body weight with my hand to reduce roughly 80-95% of the vibration noise. So I'm seeking helps from forumers which have knowledge, experience and wisdom to solve this problem. Quote:
#2 |
Sounds like this is a sealed and not ported sub. Sounds like the rear panel (with amp) is flexing as the air is shifted. I would have thought that if the seal around the amp plate is broken, that this would have made the pressure escape and not flex the panel. Is the panel made of cardboard?
#3 |
I don't think the steel plate will be flexing, more likely the screws will be loose.
Second law is your friend. |
#4 |
first stapel/nail the wool back,then put the backplate back wil a seal.
this could be a silecone/rubber or foam seal. make sure the screws are thight .
one good thing about music ,when it hit you feel no pain. so hit me with music.
#5 | ||
Anyway, it doesn't have any seal around it, just screw directly and side mates with woof/MDF material directly. The panel is made of metal. (normally plated steel I think) Quote:
Hm.... If I put a seal around the panel/plate, then I couldn't reduce it simply ^^ would like to find better solution. Of course I will put back the wool back first ^^ But I think the main problem is not sealing. |
#6 |
You can reinforce the panel or seal it off from the back pressure. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#7 | |
Seal it off from back pressure ? what does that mean ? do you mean to apply seal, thus possibly it is more affected (flexing) by the air pressure inside ? or make it leak ? Reinforce is a better way, but is there any method that able reinforcement of the back panel without making degradation of SQ, permanent damage (to the enclosure) ? In other words, can I make a reinforcement structure that is reversible/safe ? (at least won't harm the woofer) Regards, Leong. |
#8 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Yes, it needs to be resealed but the attachment mechanism isn't working for you (stripping out)..'long term'........
Depending on the stiffness of the electronics " plate" the silly woodscrews have to go. Use thru-bolts with washers & lockwashers. The overlap of the plate should be enough to use a 1/2 " flat washer (Check how much)...have the flat washer, lockwasher, nut on the outside (Duh!)....drill all the way thru...probably 5/8" MDF wood. When this is all considered........you might consider doubling the amount of screws (Now thru-bolts). Of course it would require you to drill out new holes in the Plate assy. __________________________________________________ _____Rick....... |
#9 | |
The problem now is with the metal flexing, I think the only way to stop it effectively is to make reinforcement in the middle. I will take picture (of dismantled) when I get hold of better camera. |
#10 | |
I attached some picture. 1st and 2nd picture is the woofer with back panel attached (mounting screw removed) 3rd picture is the internal near the driver. (taken without any intention though) don't know why there is black paint within the box. 4th is backpanel removed, and there is a thin paper-like material sandwiched between wood and metal. |
| headphones for nosie cancellation project | branm | Parts | 0 | 11th August 2011 05:05 PM |
| Vibrating capacitor | blue lander | Tubes / Valves | 14 | 11th February 2011 03:50 AM |
| New NHT Classic 3 woofer vibrating. Help neeed | spinnerbait15 | Multi-Way | 8 | 23rd June 2010 02:01 AM |
| Why is my amp vibrating? | wwenze | Chip Amps | 4 | 13th May 2009 03:50 PM |
| Vibrating cutter...any available | gmphadte | Parts | 10 | 7th December 2007 08:10 AM |
