Vibrating nosie from woofer - Page 2 - diyAudio
Old 25th January 2013, 01:16 PM   #11
epa is offline epa  Netherlands
i thought the problem was the metal ratling against the wood.
if the elctronics are ratling against the metal,i would sugest to aply some epoxy
between the plate and the part thats rattling against it.
i don't think the metal has become more flexible over time
just my
one good thing about music ,when it hit you feel no pain.
so hit me with music
. hr driver db
Old 25th January 2013, 01:21 PM   #12
just my
Will further investigate to make sure which noise that it produce.
If metal ratling against wood, is easy to idenfiy.
But if electronic (or whatever stick to it) is ratling with the metal, then it is hard to distinguish. If I open the back panel, then it will not vibrate.
However, I will take notice of these few point in my testing.
Old 25th January 2013, 08:50 PM   #13
You could put the plate amp in an external box and close the back of the speaker with some proper piece of wood.
Just a thought
Old 26th January 2013, 12:14 AM   #14
Just a thought
Yeah, I have some idea about it before, which is make it ported woofer box, but I will left it as last resort. (wanted to preserve its original sound properties)
Old 27th January 2013, 05:39 AM   #15
Hm.... I'm had confirmed that this is not cause by flexing alone. But came from parts attached to the backpanel. When I'm going to suppress the vibration using my hand press against the back panel, first its sound increase in pitch ( some pressing force). If apply alot of force, the the vibration is reduce to inaudible state.
However, this also apply to only some area only (not all area at backpanel can be pressed to reduce the noise. I looked inside, it was somewhere around the transformer ^^ I check all (I really mean all & every) securing mechanism (bolts, buts, etc) and they are firm and secure.
The inside layout is as per attached, the effective press-suppressing area is around the transformer and slightly toward the heatsink. The heatsink is attached to the back panel for better heat dissipation using white colour adhesive.
Any idea how and why it producing noises ? most importantly how to suppress ^^
Old 27th January 2013, 08:41 AM   #16
If the amp plate attaching screws are stripped or loose, you can use wood glue to build up the inside of the holes. I've used a big toothpick to get glue into the holes. Don't FILL the holes!!! Just coat the inside of the screw holes. Wait for the glue to dry. That way the screws will have something stronger to bite into.
MLStrand56
headphones for nosie cancellation project branm Parts 0 11th August 2011 06:05 PM
Vibrating capacitor blue lander Parts 14 11th February 2011 04:50 AM
New NHT Classic 3 woofer vibrating. Help neeed spinnerbait15 Multi-Way 8 23rd June 2010 03:01 AM
Why is my amp vibrating? wwenze Chip Amps 4 13th May 2009 04:50 PM
Vibrating cutter...any available gmphadte Parts 10 7th December 2007 09:10 AM
Copyright 1999-2017 diyAudio
