Tony Gee did it, it's on Data-bass...should I do it?
Old 26th January 2013, 09:46 PM   #21
OscarS is offline OscarS  United States
Originally Posted by turbodawg View Post
Once the box gets small enough, the tapped horn will have the same sensitivity and frequency response as a ported design of the same size. Always model your driver from a tapped horn design in a ported design of the same volume.
As tapped horns get larger they can trade low frequency extension for sensitivity and output while maintaining a relatively flat frequency response.
Whereas ported designs mostly improve their low frequency extension (a bandwidth increase), and drop in sensitivity.
I totally agree with you, but I will add that even in a small tapped horn that ends up with the sensitivity of a standard ported box, you can still get two, if not three excursion minimums within the passband of the tapped horn, that you can't get in a standard ported box no matter what.
Old 27th January 2013, 07:43 AM   #22
David_Web is offline David_Web  Sweden
I have made a fairly small TH and it showed a minimum gain of two of mouth excursion vs driver excursion through the entire passband, the mouth was the same size as the driver.
A ported box can not do that.
Old 27th January 2013, 08:42 PM   #23
weltersys is online now weltersys  United States
weltersys's Avatar
David,
A ported box can not do what?
What do you mean by "mouth excursion"?
What do you mean by "a minimum gain of two"?
Old 28th January 2013, 10:17 AM   #24
A ported cab can not increase it's apparent output at high frequency as you only have a direct radiator. Only at the low corner does the port increase output.
Mouth excursion is the movement of air in and out of the mouth just as if it was a direct radiator doing the same work with the same area.
As can be seen a small movement of the cone results in a larger movement at the mouth. Mouth area is the same as Sd and you could imagine a driver in a sealed box with the same excursion as the mouth.
You can see this increase of air movement as gain.
Only way below tuning does the TH stop increase output making a sealed box a better alternative below 26Hz.
A minimum gain of two means that for every movement the cone does the mouth does at least the double.
Tony Gee did it, it's on Data-bass...should I do it?Hide this!Advertise here!
Well... it exceeded my expectations big time! (Tony Gee LBS & HifiMeDIY TK2050) Billyo Multi-Way 4 14th February 2012 08:48 AM
Tony Gee Mudulus? dtaylo3 Multi-Way 6 11th November 2011 03:56 PM
Matching a TK2050 to Tony Gee LBS Billyo Class D 11 23rd April 2011 01:46 AM
Tony Gee or Zaph's all metal Sea's design? ShinOBIWAN Multi-Way 7 10th August 2005 04:07 AM
Where is Tony Gee?? garfieldcat Multi-Way 3 26th June 2004 04:46 PM
